Unstable evening conections?
- Unstable evening conections?
- « Previous
- 1
- 2
- Next »
Re: Unstable evening conections?
30-01-2015 6:02 PM
ah, OK. Fair enough
Message 16 of 24
(451 Views)
04-02-2015 3:27 PM
well, BTOR engineer paid a visit today. Tested the line and could find no fault. He re-routed the Master Socket into the study and fitted a Mk 3 faceplate. Said that it might be REIN but that there was little more that could be done
Message 17 of 24
(451 Views)
04-02-2015 5:18 PM
But 17:15 and the speeds take a dive again:
http://www.thinkbroadband.com/speedtest/results.html?id=142306998644593730008
Message 18 of 24
(451 Views)
04-02-2015 5:22 PM
Are you running the test wired or wireless?
Message 19 of 24
(451 Views)
04-02-2015 5:47 PM
always wired
Message 20 of 24
(451 Views)
04-02-2015 5:54 PM
I started reading this thread and thought exactly the same a jelv before I even saw his post! It sounds like exchange/VP congestion to me
Edit: The title helps cause confusion, because there doesn't seem to be any "connection" problem, it's download & upload speeds that are the issue.
Message 21 of 24
(451 Views)
04-02-2015 7:13 PM
The OP has another thread on this - http://community.plus.net/forum/index.php/topic,136306.msg1195464.html#msg1195464
It's already been identified as a congested VP.
@ shure - Which exchange are you on?
Message 22 of 24
(451 Views)
04-02-2015 7:34 PM
How confusing, 2 threads. Thanks for the link. It would be appropriate to continue with this issue, including the answer to that question on the other thread (as Tony is on the case).
I'd suggest this thread be locked in favour of the one linked.
Message 23 of 24
(451 Views)
04-02-2015 8:57 PM
Mod Note
Thread locked in favour of linked topic
Message 24 of 24
(451 Views)
- « Previous
- 1
- 2
- Next »
