Unstable evening conections?
- Unstable evening conections?
26-01-2015 9:16 PM
I do have several people using the connection at various stages, more so than during the day (usually), but in the past I can't say that I've noticed such large fluctuations and gaming in particular has suffered much more recently. Any ideas?
Re: Unstable evening conections?
26-01-2015 9:26 PM
Are you using the plusnet modem, or a third party one, as some perform better than others (a bad one will sync at a high speed, but struggle to maintain it, a good one will sync slightly slower, but never drop sync). I've found both plusnet modems quite good in this regard
26-01-2015 9:37 PM
26-01-2015 9:40 PM
27-01-2015 11:06 AM
27-01-2015 11:11 AM
27-01-2015 11:12 AM
Quote from: plusnettony
Our faults team will be picking up the ticket you've raised shortly, and they'll pass details over to BTw for you for further investigation.
er, I didn't actually raise a ticket. Should I do so?
27-01-2015 11:51 AM
To get around it, I got a new router that I could tweak the SNR to replace the free technicolor. I set it higher during the day[7db currrently] so that when the interference starts it doesn't drop below 6db during the night. As previously if it got below 5db my connection would become unstable.
So take note of the SNR on your router when its stable and when not, which probably drops below 6.
27-01-2015 11:55 AM
27-01-2015 12:59 PM
28-01-2015 12:11 PM
30-01-2015 5:14 PM
1. Best Effort Test: -provides background information.
Download Speed
3.4 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.4 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
At least the roads will be clear tonight
All test done on a wired connection. Son's out of the house so can't be hogging anything. Ping's relatively OK at the moment at 42ms. Normally it's in the teens but it has been known to shoot into triple figures some evenings
30-01-2015 5:40 PM
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
30-01-2015 5:43 PM
30-01-2015 5:53 PM
