Unlocked HG612 modems
- Unlocked HG612 modems
14-02-2014 6:20 PM
Re: Unlocked HG612 modems
14-02-2014 6:55 PM
The only downside is certain types of firmware can cause higher error rates which means the line will more likely become interleaved when paired to the ECI box on the street.
The unlocked ECI's is also something to consider if your more technically minded / network savoir faire.
mikehiow did some good stuff with the ECI/r
http://eci.vxr.in/
15-02-2014 1:18 AM
15-02-2014 8:26 PM
16-02-2014 2:06 AM
http://www.freewarefiles.com/HG612-Modem-Stats_program_84567.html
You get the usual Broadcom raw data logs & can also graph snapshot and/or fully automated ongoing data on a user determined schedule.
I am a regular visitor/contributor to the KItz forum & also call in here from time to time.
16-02-2014 2:06 AM
16-02-2014 4:01 PM
16-02-2014 6:10 PM
Have you blocked the update or is it just that it hasn't happened yet?
16-02-2014 6:29 PM
16-02-2014 7:03 PM
Does it include implementation guidance or is that lurking somewhere on Kitz?
16-02-2014 11:06 PM
Quote from: rbel
It's included in the download zip file ("HG612_Programs-Setting_Up_Instructions.pdf" - in the Scripts folder) & it is also lurking on Kitz.
17-02-2014 12:33 PM
Quote from: goldenadsl http://eci.vxr.in/ these are pretty good stat. Useful.
ive a ECI B(the one with out metal sockets)
is this information relating to my connection i've been concerned about my connection but without stats i've been unsure how to resolve it
17-02-2014 7:10 PM
ECI r needs to be unlocked to get the line stats....
17-02-2014 9:14 PM
18-02-2014 7:52 PM
Although that being said, the new unlocked firmware versions (35) of the HG612 make it not far be hind the eci r on sync terms.
A chart from Kitz gives a good overview.
http://huaweihg612hacking.files.wordpress.com/2013/03/graph.jpeg?w=714
