Unlimited fibre speed
IvanC86
I had unlimited fibre installed at 1pm today, I have just checked the download speed and it is only 3.1MBPS, and thats the same as when I was on normal ADSL broadband....I was stated the speed I would receive was 55MBPS(I assumed it would be nearer to 15MBPS).
The only reason I went for fibre is due to the speed and it appears that its no faster, Can someone please shed some light on this as im a bit perplexed.
31 REPLIES 31
Oldjim
Resting Legend
Fixes: 63
Re: Unlimited fibre speed
Current line speed here needs updating https://portal.plus.net/my.html?action=data_transfer_speed
IvanC86
Thanks,
So what does that mean for me Oldjim?
Oldjim
Resting Legend
Fixes: 63
It means that the Plusnet profile won't have increased if it is the same as with ADSL - what does it actually say as the current line spoeed
You can either phone or wait for it to be picked up tomorrow
Of course it may well sort itself out by the morning
IvanC86
Hi Jim,
Ive just checked again with the BTW speed test and here are the results -
Download speed (mbps) - 2.81
Upload speed (mbps) - 12.81
Ping Latency (ms) - 32.75
Ivan
Chris
Legend
Fixes: 169
I'm taking a look now.
IvanC86
Thanks Chris,
I look forward to your reply.
Kind Regards,
Ivan
dick:quote
Chris
Legend
Fixes: 169
Give it 5 minutes and if you're not seeing a better speed try logging in to the router and disconnect/reconnect.
IvanC86
Hi Chris,
Im currently at work (till 5.30 and it will be peak usage time) so is there any way that you can check the speed I am getting remotely?
Ivan
dick:quote
Chris
Legend
Fixes: 169
Only the speed you are connected at, not the throughput. You're connected at just under 65Mb so I'd expect around 55Mb on speedtests.
IvanC86
ostcode:
Phone exchange:
WHITWELL
Estimated line speed:
53Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-11-29 19:11:57
Current line speed:
63.8 Mb
Ive just checked this but last nite it was 3.2MB on that. Should I see what the speed is again when I get home around 6pm.
The speed it shows of 63.8MB, that is for my address(6 queen street) and not my current location (work) as i know my work speed is about 80mb.
Ivan
IvanC86
Just got my wife to run a BTW performance test.
Download speed(mbps) -17.97
Upload Speed(Mbps) - 12.38
Ping Latency(ms) - 45.38
and a 2nd time just for a safety
download speed - 18.32mbps
upload speed - 12.47mbps
ping - 33.50ms
AndyH
Is she running the tests wirelessly?
Fixes: 385
Is that wireless or wired ?
Needs to be a wired test to get accurate results , too many factors can affect wireless speeds.
AndyH beat me to it
IvanC86
Haha 2 for the price of 1!
yes thats wireless.....without sounding crass I cannot be arsed trying to explain to her how to wire the connection to the pc from the other side of the room. Id rather try and do it when i get home at 6!
"you can take a horse to water but you cant make it drink" comes to mind!
