Unlimited Fibre down to 9mb
Bloodfish
unlimited fibre now down to 9mb download
Your broadband service
  • Product:  Unlimited Fibre
  • Estimated Download Range:  8 - 9Mbps
  • Estimated Upload Range:  3.5 - 4Mbps
  • Minimum Guaranteed Speed:  7.7Mbps
  • Current Line Speed (Download):  40Mbps
can anything be done please?
BF
7 REPLIES 7
Fixes: 334
Re: Unlimited Fibre down to 9mb
@Bloodfish Sounds like you have a major issue there. As staff response is lacking maybe we can advise - can you please provide the details requested below?
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Fixes: 457
Moderators Note
This topic has been moved from Full Fibre to Broadband
Bloodfish
Hi
thanks for the direction (will update when I can)
Also why has this been moved to broadband I thought I was on on unlimited fibre?
Fixes: 334
No problem - I'm around until ~9PM. It has been moved to broadband as you are on Fibre To The Cabinet (FTTC), not Fibre To The Premises (FTTP or Full Fibre)
Fixes: 457
@Bloodfish
All copper based services, that’s ADSL, Fibre and Fibre Extra are referred to as Broadband on this forum. Full Fibre is the new Fibre to the Property (FTTP) service.
Edit
@jab1  types faster than me.
Bloodfish
Did a line test and it sounded like someone frying chips - I have reported a fault on the line / thanks for now.
P.s. where are my broadband connection details in my account area they don’t seem to be there anymore they used to be here
https://www.plus.net/member-centre/broadband/connection-details
Fixes: 334
Good - a line fault is often easier to sort than a broadband one - let us know what happens. Which connection details do you mean - sorry, as I'm no longer a PN customer, the details I can access are a little restricted.
