Unlimited FIbre Speed
jasonbwatson
I signed up for Unlimited Fibre and should get around ~80 mbps ~20 up speed. I'm currently getting ~7 download speed although the up speed is ~17 at times.
I'm guessing my line hasn't been profiled? since the BT engineer who tested before he left was getting 80 up and 20 down.
The connection has been active since the 1st of this month so maybe i'm still waiting for the final checks to be complete and should be more patient  Wink?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Unlimited FIbre Speed
Hi jasonbwatson,
I'm just taking a look into this now for you.
Chris Pettitt
Cloud Environments Engineer
Plusnet Staff
Plusnet Staff
Fixes: 5
That should be sorted for you now.
If you could just restart your Plusnet Router (not the Openreach Modem), you should start to notice a difference.
Chris Pettitt
jasonbwatson
Thanks Chris i'll give it a go.
