Unknown username on router
- Re: Unknown username on router
05-02-2015 9:41 PM
Very surprised to see a new username for the internet connection is saved there.
Instead of my username and password, it was showing '<snip> and a saved password
I changed it back, but how is this possible?
[Moderator's note by Jim (Oldjim) somebody's username removed but noted for staff as he may be wondering why he can't connect all because the TR069 system screwed up ]
05-02-2015 9:52 PM
Try disabling it in the router.
05-02-2015 9:55 PM
05-02-2015 10:04 PM
Are you sure it can't be disabled in the router ?, many routers can, but I don't have a Technicolor so I don't know in this instance.
05-02-2015 10:10 PM
05-02-2015 10:40 PM
I thought TR-069 was a pull request not a push one (i.e. the router asks for it when doing its first boot)
06-02-2015 10:20 AM
Phil
06-02-2015 2:26 PM
06-02-2015 5:08 PM
Quote from: Oldjim I have a TG582n and there isn't any way unless you can do it via telnet
service system modify name=CWMP-S state=disabled
saveall
I did that when I went on the IPv6 trial which requires using a different username.
06-02-2015 5:22 PM
