Unknown Gateway?
- Unknown Gateway?
Unknown Gateway?
19-02-2010 7:42 AM
I just went onto PN's what gateway and I get "You are currently connected to the "unknown" gateway." What on earth is this?
Message 1 of 3
(844 Views)
2 REPLIES 2
Re: Unknown Gateway?
19-02-2010 8:14 AM
Read this http://community.plus.net/forum/index.php/topic,83185.0.html
particularly this post from Bob http://community.plus.net/forum/index.php/topic,83185.msg684822.html#msg684822
Message 2 of 3
(283 Views)
19-02-2010 2:10 PM
Don't worry about the 'unknown gateway' message - the gateway is a proper one, just not (at the moment) supplying the information the gateway checker needs to identify it. A better description would probably be:
"The tool currently could not identify your gateway, it does not mean that anything is wrong".
This will be fixed.
David
This will be fixed.
David
David
Message 3 of 3
(283 Views)
