Unexplained speed variations
- Unexplained speed variations
24-05-2009 6:19 PM
My router is a Netgear DG834 v3 (no wireless) and is plugged into the (BT installed) extension socket.
Here are the router statistics:
Speed: 5984kbps down 544kbps up
Atten: 31db down 7db up
Noise: 12db down 13db up.
Throughout the tests, these figures hardly varied. Attenuation did not vary at all.
When I plugged the router into the test socket behind the master socket faceplate, it gave these results:
Speed: 6432kbps down 576kbps up
Noise: 11db down 13db up
I have also tried my SMC Barricade router. Here are its speed figures.
Speed: 3296kbps down and 640kbps up.
For comparison, the Netgear at this time, was giving speeds of 6176kbps down and 544kbps up.
I cannot improve on these results.
Keith
Re: Unexplained speed variations
24-05-2009 6:31 PM
However it is appears to be showing consistency with the variable upload speeds as well as download.
Could you post the results from Weds 20th and Mon 18th?
24-05-2009 6:50 PM
Here are the Netgear router stats you asked for.
Wednesday 20th.
Speed: 5568kbps down 544kbps up
Atten: 31db down 7 db up
Noise: 13db down 13db up
Monday 18th.
Speed: 6496kbps down 576kbps up
Yes, the SMC has been in a cupboard for over three years!
Thanks.
Keith
24-05-2009 7:16 PM
Bearing in mind there are no bell wire issues (sorted in the other thread), the only other results that I think may be of relevance are the Netgear results with the two different filters.
24-05-2009 7:27 PM
Keith
24-05-2009 7:43 PM
24-05-2009 8:14 PM
'T' filter.
Speed: 6688kbps down 576kbps up
Noise: 10db down 13db up
'Rat Tail' filter.
Speed: 6176kbps down 544kbps up
Keith
24-05-2009 8:30 PM
well apart from the varying download speeds and occasional drops, it's the upload speeds that suggest either a modem/router problem or an exchange linecard problem. It's strange that just two values are cropping up 544 & 576 with the Netgear though the SMC gave 640 when the correct value should be 448, so there's a few extra tones coming into play which shouldn't!
Although you've tried your SMC, as it's been out of commission for so long, it's advisable just to check this out with a loan router to confirm the problem.
Hopefully Jameseh can pick this up and help out with a loan router on Tuesday when the Comms team are back in.
26-05-2009 11:32 AM
I've arranged for a loan router to be sent, which should be with you in the next 2-3 days.
Please do let us know how you get on.
26-05-2009 12:36 PM
27-05-2009 9:16 AM
Thank you very much for sending me a router to try. I really do appreciate it.
I'll let you know how it goes.
Sorry for the delay in replying, but we were out all day yesterday.
Keith
29-05-2009 2:03 PM
I've done some tests with it and here are its statistics.
Speed: 7616kbps down 672kbps up
Atten: 29.0dB down 16.5dB up
Noise: 12dB down 13dB up
In comparison, here are the latest statistics for my Netgear DG834.
Speed: 6336kbps down 544kbps up
Atten: 31dB down 7dB up
Noise: 10dB down 13dB up
During all the extensive tests I have conducted over the past week or so, using the Netgear DG834, the speed varied between 6048 - 6848 (usually around 6100 and 6300) down, and 544 - 576 up. The attenuation was constant, and the noise varied by a maximum of 2dB both up and down.
During the morning, the PlusNet speedtester shows I have a download speed of 812kB/s and an upload speed of 70.8kB/s.
(I have been trying regularly for many months to access the BT speedtester, but it is permanently busy.)
Using the Speedtouch, during a morning I can download files at 790+kB/s, so they are downloading at almost my maximum speed. With the Netgear, they download at around 450kB/s.
PlusNet gives me a profile of 8000.
I hope that I have explained the situation clearly!
Any comments will be appreciated,as my knowledge of routing is very limited!
Many thanks.
Keith
29-05-2009 2:08 PM
29-05-2009 2:41 PM
29-05-2009 2:59 PM
Exactly the same, except that the 'down' sig/noise has gone to 12dB.
The Netgear statistics I gave, were taken this morning and are very similar to the ones I have got each time I take them.
Keith
