Unexplained Usenet usage
- Unexplained Usenet usage
- « Previous
- 1
- 2
- Next »
Re: Unexplained Usenet usage
03-04-2013 11:12 PM
What's your normal Internet usage like (in terms of what do you do on the Internet - any progs like DropBox etc.)?
03-04-2013 11:19 PM
I do use Dropbox for the odd document, nothing close to the amount that's being logged as Usenet. My normal usage is mainly web browsing (news, forums, social networking, buying online), a few streaming videos, some Skype.
As I was saying upthread, I wonder if Skype could have something to do with it? It's the only app I can think of that could be generating that volume of traffic - but then again, why would Plusnet categorise it as Usenet?
03-04-2013 11:50 PM
From Skype support:
Quote To work correctly, Skype requires unrestricted outgoing TCP access to:
All destination ports above 1024 (recommended)
or
Ports 80 and 443
https://support.skype.com/en/faq/FA148/which-ports-need-to-be-open-to-use-skype-for-windows-desktop
So both Skype and Usenet can use port 443. Looks like that explain things.
03-04-2013 11:54 PM
In my installation of Skype, the checkbox that says "use port 80 and 443 as alternatives for incoming connections" is not ticked! It's set up to use a much higher port number.
04-04-2013 12:00 AM
Try blocking outgoing port 443 in the routers firewall and see if that stops this reporting of usenet traffic.
I'm guessing Skype will use a alternative port if 443 is blocked.
04-04-2013 12:02 AM
04-04-2013 7:48 AM
04-04-2013 8:26 AM
You could try using Skype (over port 443) and running Wireshark to make sure the packets are being captured and treated properly by PN's traffic management system. I believe it should have the value 0xa0 (Titanium) in the Differentiated Servcies Field.
04-04-2013 9:17 AM
04-04-2013 9:45 AM
On this basis secure web pages are presumably classed as usenet.
10-04-2013 7:22 AM
- « Previous
- 1
- 2
- Next »
