Unexpected e-mails this morning
HughA
Yesterday I was switched to Unlimited from Value as I had requested and that seems to have happened without problem.
This morning I received 2 unexpected e-mails from PlusNet.
The first said that interleaving was being turned off at my request.  I didn't make such a request!
The second said that I was now running on an "up to 20 Mbps service". Well I'm not.  I'm on ADSL1 on a 21CN exchange which seems right for my 60dB attenuation line running at about 3Mbps.
So is this a result of the switch to Unlimited or a consequence of my recently closed ticket resolving a line fault? Whatever the reason I assume that when it all takes effect I will go through a period of instability followed by a switch back to ADSL1 with interleaving on.
Were the changes part of an automated system or is someone at PlusNet trying to see if my line will go faster? Has anyone else switching from Value to Unlimited receive similar e-mails?
Fixes: 61
Re: Unexpected e-mails this morning
These are as a result of automated scripts.
Maybe a DC member will pop in and explain further.
Customer and Forum Moderator.
Fixes: 62
I got exactly the same - ignore it.
For some reason when changing to Unlimited 12 months contract you get emails as though you are a new customer - nothing actually changes
HughA
Thanks Oldjim.
Hi HughA,
We currently have a open problem(73795) regarding the interleaving one, it nothing to worry about and if it needed turning back on it's something we can easily do, here is more information on <a href="http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml#interleaving">interleaving</a>.
You're also still on ADSL1 on 21CN.
