Understanding the finer points of DMT...
- Understanding the finer points of DMT...
- « Previous
- 1
- 2
- Next »
Re: Understanding the finer points of DMT...
25-11-2008 4:43 PM
OldJim & BarryZ - thanks for that...
Well the man from ADSL Nation confirms that the bell wire IS filtered and that there would be nothing to be gained by snipping it - I may do so anyway once I find out how to disconnect the router without losing my sync speed... it's a D-Link DSL-2640B.
Is it ok just to switch it off then remove it from the line or is there a more elegant way?
Thanks,
Thanks,
Message 16 of 19
(255 Views)
25-11-2008 5:10 PM
You could disconnect it via the web console, and then remove the power.
That's about as elegant as it gets
Message 17 of 19
(255 Views)
25-11-2008 5:24 PM
Oh - I presume that's via the 'disconnect' button at the bottom of the ADSL Setup screen. Should have looked there before posting....
'that's why I call myself a PN newbie' says he donning his dunces hat and slinking back into the his corner...
Thanks James!
Thanks James!
Message 18 of 19
(255 Views)
25-11-2008 6:40 PM
I would just turn the router off and disconnect the bell wire, wait 20 minutes and turn the router back on.
I believe your sync speed will be higher and your connection will be more stable with the bell wire disconnected.
Message 19 of 19
(255 Views)
- « Previous
- 1
- 2
- Next »
