Understanding synch speed
- Understanding synch speed
21-05-2008 4:55 PM
Hi.
My router says it is synching at 8064kbps. It has been at that speed for almost a week.
However, when I go to https://portal.plus.net/my.html?action=data_transfer_speed, that page says my speed 'based on my synch speed' is 3000.
This ties in with the actual throughput I'm getting now, which is around 2800kbps.
My only question is, is the 3000 reported on the link given something I (or PN) have control over, or do I just have to wait for the 'system' to realise that I'm synching at 8000, and adjust itself?
Roger
Roger
Message 1 of 3
(847 Views)
2 REPLIES 2
Re: Understanding synch speed
21-05-2008 5:00 PM
The speed show at the link you've give should match the IP profile when you run a BT speedtest. I'd suggest having a read of the information on Jameseh's blog for more info on how these work.
I'll go dig out the link to it unless someone else posts it first
*Edit - found it
http://community.plus.net/comms/2007/07/02/broadband-speed-faults-how-to-diagnose/
*Edit - found it
Message 2 of 3
(290 Views)
21-05-2008 5:31 PM
Ok thanks. Will do.
Message 3 of 3
(290 Views)
