Understanding High Signal Attenuation
Fixes: 357
Re: Understanding High Signal Attenuation
@itlity Sorry for the late reply. Your Technical Log doesn't look out of order - although you are on the low side of a low speed range,
Following @bmc 's comment re: FTTP - which exchange are you on?
itlity
No worries.
There was/is an issue on the line, the reset has hidden it again for the moment.
Many thanks to all for the kind support. Have a good week-end!
