Uncapping upload
- Uncapping upload
Uncapping upload
10-10-2011 3:50 PM
I have just had my broadband activated. My upload is capped at 448kbps and i believe this can be uncapped? What will it go to uncapped or does it depend on the line length also?
I have a router that i can manually set the SNR. Does this cause a problem doing this whilst in the BT training period? Is it better to use my router or get plus net to set the SNR?
Regards
Re: Uncapping upload
10-10-2011 3:53 PM
I can place the order to uncap the upstream, this normally goes through in 24 hours. I wouldn't advise tweaking the SNR in your training period though.
Jojo
10-10-2011 4:03 PM
Order's placed now. I've sent you a confirmation email.
Jojo
10-10-2011 5:36 PM
10-10-2011 9:55 PM
10-10-2011 10:21 PM
If you upload speed is below 448Kbs you are capped.
11-10-2011 9:15 AM
11-10-2011 9:46 AM
Oh well.
11-10-2011 9:48 AM
11-10-2011 9:50 AM
11-10-2011 9:55 AM
Edit: Will I be notified when it is uncapped or will it just happen?
dick:quote
11-10-2011 11:32 AM
There's a ticket on the account that should notify you when the order's done, though you won't need to do anything - the router will pick up the uncapped upload automatically
11-10-2011 11:44 AM
Thanks for the help everyone!
dick:quote
11-10-2011 12:52 PM
Quote from: Joanne Hi chrish16,
Jojo
Hi jojo
I'm using my router that i had with my previous ISP on LLU, and i had it lower the SNR. I have connected this router with Plus net and only changed the username and password for ADSL. If i change the SNR now it will make a dramatic change in sync speed and I'm worried this will really confuse BT's profiling and mess my line profile up. It seems fine at the moment. I can post line stats later this evening.
I get around 7.2Mbps on download testers and i sync at around 8026kbps and my SNR around 3.5 to 4 db down
My line profile on BT speedtester was 7150kbps i think
Do this sound right?
11-10-2011 1:46 PM
That's about as good as an up to 8Mb line will get I'd leave it as it is to be honest.
