turn on suggestions
Uncapped?
- Uncapped?
Uncapped?
Uncapped?
14-01-2014 12:38 AM
There was apparently an uncap request order sent for my line, a little while ago, about a week or 2 ago, I've re-done the tests recommended and everything seems exactly the same, including my 0.36mpbs upload rate,, not sure if any of this is relevant or helps at all:
Link Information
Uptime: 4 days, 13:43:47
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,176 / 9,480
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,366
Data Transferred (Sent/Received) [GB/GB]: 3.59 / 52.61
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 22.5 / 37.0
SN Margin (Up/Down) [dB]: 28.0 / 2.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 438 / 0
FEC Errors (Up/Down): 5,506,208 / 100,840,477
CRC Errors (Up/Down): 53,666 / 25,477
HEC Errors (Up/Down): 24 / 133,164
Still no estimated line speed for my line>
BTW Performance test:
Downspeed 7.93mbps
Up-speed 0.36
ping 43.50
Just wondering if theres anything that can be done to improve my connection since I play a lot of games online, Primarily Dota2 and recently and for quite a while infact I've been getting rather horrendous lag spikes, that cause me to disconnect entirely and are usualy followed by a 900ms+ ping/latency followed by a high packet loss.
Link Information
Downspeed 7.93mbps
Up-speed 0.36
ping 43.50
Re: Uncapped?
Re: Uncapped?
14-01-2014 10:15 AM
Re: Uncapped?
Re: Uncapped?
15-01-2014 2:21 AM
Thank you very much, I mostly use my computer/do my gaming during the nights, so I'll have a test, play some games and see if it resolves anything.
Thanks for the continued support.
