Uncapped upload speed
backie
Hello, I just had my ADSL activated and was hoping I could have my upload speed uncapped as seen below my router syncs at more than the standard capped adsl1 448kbps speed.
Thanks,
Rob
DSL Modulation
ITU G.992.1(G.DMT)
ANNEX Mode
ANNEX A
SNR Down
6.0 dB
SNR Up
16.0 dB
Line Attenuation Down
56.5 dB
Line Attenuation Up
31.5 dB
Path Mode
FastPath
Data Rate Down
2720 kbps
Data Rate Up
448 kbps
MAX Rate Down
3008 kbps
MAX Rate Up
860 kbps
POWER Down
17.5 dbm
POWER Up
12.5 dbm
CRC Down
720
CRC Up
0
Fixes: 62
Re: Uncapped upload speed
Looking at the numbers I rather suspect that your exchange doesn't have 21CN enabled - you can check here http://usertools.plus.net/exchanges/
Fixes: 205
Unfortunately your on 20cn which means we can't uncap your upload speed for free.
We offer Max Premium which would increase your upload speeds to around 823kbps.
This costs £7.83 a month and can be requested here
 Matthew Wheeler
Fixes: 62
it would also seriously impact your download speeds so not recommended
whoops - look who was confused
Fixes: 20
Max Premium isn't ADSL2+ Annex M, so download speed should be unaffected.
