Uncap upstream
- Uncap upstream
Uncap upstream
02-11-2014 9:13 PM
Re: Uncap upstream
02-11-2014 9:20 PM
What does this say about WBC on 21CN http://usertools.plus.net/exchanges/
Also what are your router stats http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
This is the bit we are interested in
Link Information
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 888 / 3,894
Data Transferred (Sent/Received) [MB/GB]: 501.28 / 4.53
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 26.8 / 50.0
SN Margin (Up/Down) [dB]: 8.4 / 3.0
Re: Uncap upstream
03-11-2014 12:41 PM
Just to confirm, I have placed the order this afternoon to upgrade you line to Max Premium as you requested
This should be completed in the next couple of days
Hope this helps
Regards
Matt
Re: Uncap upstream
03-11-2014 12:46 PM
Quote from: Cruise85 Just to confirm, I have placed the order this afternoon to upgrade you line to Max Premium as you requested
I presume he's agreed to the extra £7.83 per month for this upgrade?
Re: Uncap upstream
03-11-2014 1:15 PM
The post was just for a clarification of the workplace request to upgrade
Regards
Matt
Re: Uncap upstream
05-11-2014 1:08 PM
Re: Uncap upstream
05-11-2014 1:21 PM
Quote from: Oldjim The first question is whether you are on 20CN or 21CN
Link Information
Hi Jim,
Copy of line stats for your perusal below. Line seems in good order to achieve a slightly higher upstream would you agree? Extremely low error count on this line - only ever increases during a thunder storm, otherwise a rock solid sync, quite surprising as a large chunk of the loop is copper on sticks and in a rural location. My exchange is a 20CN.
ADSL Information ( SDSLADSL Firmware Version: 232201_A)
ATM Statistics TX Cells RX Cells TX CRC errs RX CRC errs
326571 295767 0 0
SDSL StatusADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
G.DMT SHOWTIME 448000 8128000 7 31
Re: Uncap upstream
05-11-2014 2:12 PM
I thought Max Premium upgrade was quick (overnight), but it may be one of the 5 working days orders in which case it won't change until next week.
Re: Uncap upstream
05-11-2014 2:29 PM
Re: Uncap upstream
06-11-2014 9:24 AM
Re: Uncap upstream
06-11-2014 3:15 PM
dick:quote
