Uncap upload speed
davidbackhouse
Uncap upload speed
Is it possible to get upload speed increased by removing the cap on my line?
8. Data rate: 888 / 14336
9. Maximum data rate: 888 / 19124
4 REPLIES 4
TheMightyAJ
Fixes: 126
Re: Uncap upload speed
Hi @davidbackhouse,
Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net.
 Alex H
Fixes: 313
@davidbackhouse
888k is the maximum upload sync when interleaving is on
davidbackhouse
OK, but if 888k is the maximum speed with interleaving on (which it is) then what did Plusnet do yesterday?
Hi there David, I've tested your line and can see that you're staying connected to the internet. However there are some automatic settings on your line which are limiting the speed you're able to get on the line.
I've arranged for the line to be reset to try and fix this. The reset normally takes 4 hours to complete. After 4 hours your router will need to be powered off for 10 seconds and then turned back on. When it reconnects we'd expect the speed to be normal again, but it can take 24 hours before everything fully updates."
What automatic settings are these which are being referred to?
Fixes: 313
A line reset will reset the DLM to the default which will turn interleaving off. However, if the DLM has previously decided that interleaving was necessary to reduce errors then it will very likely turn it back on again after a while.
