Uncap Upstream again Please
philstoke
I had my upstream uncapped quite a while ago from about 0.30 - 0.40 mb/s to 1mb/s, now after having quite a few outages last week it has dropped to the lower speeds again. I have tried rebooting the router but it doesnt make any difference, my download speed of about 10mb/s has not changed
Could someone re-uncap it again please
Plusnet Staff
Plusnet Staff
Fixes: 29
Re: Uncap Upstream again Please
Hi Phil,
I've taken a look at your asset with BT Wholesale and details our side, the upstream is uncapped for both
 Paul Tarr
 Plusnet Network Operations
philstoke
Thanks for the quick reply
Thats odd, strange that the download speed hasn't changed but uploads have, somewhere I have another router, I willl have to dig it out and see if its the router that is the problem
Fixes: 20
Yeah that might be a good call to try another router. Before you do that I'd have a quick look through these checks from this link as they can help as well http://goo.gl/BZE3NM
 Ben Babinski
Fixes: 26
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
Plusnet Staff
Plusnet Staff
Fixes: 5
Having had a quick look at your line, I've noticed a number of potential restarts within the last 24 hours - this could either be yourself trying to restart the router to see if the upload speeds return back to normal, or if it isn't caused by you, could point at a potentially more serious problem.
Your line generally looks to be a little intermittent, with speeds changing quite a lot. I'm wondering if there's anything you think that might have caused that? Do you switch your router off at all?
Chris Pettitt
Cloud Environments Engineer
philstoke
Hi we did 2 or 3 restarts, but not in the last 24 hours, we have been uploading a lot over the last week, thats how we realised it was slow
Plusnet Staff
Plusnet Staff
Fixes: 5
Did you manage to try a different router?
Chris Pettitt
Fixes: 26
philstoke
Not yet, I am very busy at the moment, I will try it in 2 or 3 days time and put a message on here with the results
Fixes: 26
As you please - it does not take more than a few minutes and it is the quickest way of seeing just how much room there is for improvement.  When you are able to post that information will determine how soon that advice can be offered form the community.  PlusNet staff are very stretched at present - therefore there is more chance of obtaining an assessment of potential from a community member than a PN staff member.
philstoke
I had a few minutes spare this afternoon, so I thought I would try the easiest thing first and change the Filter and that seems to have been the problem,  it is back to the corrects speeds now, it was very odd that downloads were ok and it just affected the upload speed.
Thanks very much for all the help and advice, much appreciated
Fixes: 205
Glad to hear a new filter seems to have fixed the problems you were experiencing. Thanks for letting us know Smiley
 Harry Beesley
Fixes: 26
It good to hear that you have a resolution which you are content with.  If the problem comes back, please return to this topic and add your router stats please and someone will promptly advise.  On that occasion you might get a response from a Plusnet staff member before the community can get their sticky fingers on it! Wink Cool
Did you know that if you felt that any particular post has helped you, you can indicate that by clicking the thumbs-up button just below the post.
Hope you remain issue free!
