Uncap Upload speeds
- Uncap Upload speeds
Uncap Upload speeds
11-08-2015 5:01 PM
Hi upload speed is practically useless, appearantly i need my upload speeds uncapped as it shud be anything up to 1mb, but currently hitting 0.3 at most.,
thanks
thanks
Message 1 of 9
(1,091 Views)
8 REPLIES 8
Re: Uncap Upload speeds
12-08-2015 12:43 PM
Taking a look now.
Message 2 of 9
(777 Views)
12-08-2015 12:52 PM
Yep, the upload was capped. Sorry about that, the order to uncap should complete tomorrow.
Message 3 of 9
(777 Views)
03-09-2015 4:34 AM
thanks chris. also thanks for the quick reply. faster than the uploads anyway.
currently speed coming in around 0.5mb . less than impressed tbh. is this the best im likely to get? any way to get a realistic / accurate estimate for the line?
i had an issue with a faulty adsl filter which ive resolved but meant the line was down for a few days in a row. im hoping it will stabilise and potentially pick up, perhaps a little bit at least.
Message 4 of 9
(777 Views)
03-09-2015 12:17 PM
Message 5 of 9
(777 Views)
03-09-2015 1:20 PM
sorry to jump on the band waggon. but I seem to be having a similar problem with capped speeds. I've had the order on my line placed serveral times but it somehow seems to revert. Is it possible for someone to check if Im being capped too please?
Message 6 of 9
(777 Views)
03-09-2015 1:23 PM
Message 7 of 9
(777 Views)
03-09-2015 1:58 PM
Also what is the upload IP Profile reported as when you run the diagnostic on the BT speed test?
Message 8 of 9
(777 Views)
04-09-2015 8:35 AM
Hi Mathew,
speed seems ok now. very strange as had been down at 300k
thanks for looking anyway!
AJJ
AJJ
Message 9 of 9
(777 Views)
