Uncap Upload Speeds Please
cproctor57
Hi there, tried phoning up but 20 minute wait times are a bit too much for me.
I would like to play online games and the capped upload speed is just too slow.
Is it possible to get my upload speed uncapped? If so, is that for no added cost?
Fixes: 10
Re: Uncap Upload Speeds Please
Are you on 20CN or 21CN? On 20CN it's £7.83 per month to change to Max Premium which gives up to 832kbps. On 21CN it's free and what you get is dependant on your line but can go up to 1.3Mbps.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
cproctor57
"BT have advised that this exchange is enabled for WBC on 21CN"
I assume that means I'm on a 21CN exchange
Fixes: 10
Can you post your router stats please. If you are using a Plusnet supplied router you can find them at http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0
cproctor57
I would happily but for the life of me I can't log into my router.  I have tried resetting it multiple times and using all of the combinations of default passwords I could find but none would let me in
Fixes: 10
Either find the card that came with the router or look on the bottom of it!
cproctor57
I found the card, it actually turns out the sticker on the bottom was printed incorrectly.  Very odd.
I'll get you the stats now
cproctor57
attached is a screenshot of the config you asked for.
Fixes: 62
21CN and ADSL2+ so the uncap will probably be done tomorrow by the Team on here
cproctor57
Super thank you both very much
Plusnet Staff
Plusnet Staff
Fixes: 5
There looks to be an order already in place to uncap your upstream. I'll keep an eye on it and ensure that it goes through for you.
Chris Pettitt
Cloud Environments Engineer
cproctor57
Hi there, I think that may be a mistake as I am the only person with access to the account information, however, if it gets done, happy days!
Do you have an estimate as to when the change will take place?
Plusnet Staff
Plusnet Staff
Fixes: 5
Yep, it's due to complete tomorrow.
We're uncapping upstream on accounts so yours may have been within the batch we've done recently. I'll check the order tomorrow when it completes to make sure it's uncapped your upload.
Chris Pettitt
cproctor57
Thank you very much, that is very helpful!
cproctor57
Hi there, think my up has been uncapped (getting 0.8mb now) although that could just be to the fact it's offpeak and 4am!
