Unacceptable speeds
- Unacceptable speeds
Unacceptable speeds
15-09-2015 5:14 PM
Really since the BT system upgrades a little while back I have been getting unacceptable download speeds. When I changed from Bt to Plusnet a few months ago ...after a settling in period, I was obtaining around 6Mbps. Since the system upgrades I am getting this type of result....and this is one of the better ones It has reached the stage where Netflix and Amazon are unusable
.Results Image not loaded
1. Best Effort Test:
Download Speed : 1.29 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
This is a BT speed test.
I would appreciate someone to look into this.
Message 1 of 5
(1,139 Views)
4 REPLIES 4
Re: Unacceptable speeds
15-09-2015 5:22 PM
Our tests are showing there's a potential capacity issue in your area.
If you raise it using the link below our Faults team will investigate.
https://faults.plus.net
Message 2 of 5
(884 Views)
15-09-2015 5:30 PM
Thanks for that. The fault has been reported
Message 3 of 5
(884 Views)
16-09-2015 9:06 AM
Message 4 of 5
(884 Views)
17-09-2015 10:08 PM
When I came home from work yesterday I was delighted to see that my speed was back up to normal speed....however when I got up mid afternoon......it had dropped to 0.8 Mbs. Bit the bullet and ordered a new ADSL modem/router. Arrived today and so far I am running pretty close to the maximum promised.
I think it is sorted!
Message 5 of 5
(884 Views)
