Unable to turn interleaving off via portal
- Unable to turn interleaving off via portal
Re: Unable to turn interleaving off via portal
17-02-2015 10:58 AM
17-02-2015 11:18 AM
17-02-2015 11:20 AM
The line seems to run fine for several months and then there is a single drop which causes issues in which they activate interleaving and reset the line and I end up with a ping around double what it is without interleaving.
17-02-2015 11:30 AM
I would say that Interleaving on your line has NEVER actually been turned off. The line has been reset and it's remained on AUTO (which is initially off) and has not been set to OFF, so at the first sight of an issue that DLM doesn't like, DLM turns it On.
IF it had actually been set to OFF and Faults/CSC are placing orders to turn it on, then they should be stating that in the relevant ticket.
17-02-2015 11:31 AM
17-02-2015 11:32 AM
As you have your own thread http://community.plus.net/forum/index.php/topic,135532.0.html and the issue of ping times has now come up there going by the last post, I would have thought it better to deal with your issue in your thread rather than confuse this one.
17-02-2015 11:51 AM
17-02-2015 12:09 PM
17-02-2015 4:29 PM
Please excuse the copy and paste ...
<i>"The current proifle is IP/MAX832_6F/DMTU - Office 6dB Fast
As this line has been remotely stabilized. Please allow 2 hrs for the changes to take place advise end user to hard reboot the router and try to log in and further it takes 24 hrs for the line to stabilize" </i>
17-02-2015 5:40 PM
17-02-2015 5:41 PM
18-02-2015 6:04 PM
19-02-2015 8:47 AM
I hope performance will be better once fibre comes along next month.
19-02-2015 9:34 AM
19-02-2015 10:01 AM
