Unable to report fault
- Unable to report fault
01-06-2019 12:18 PM
Re: Unable to report fault
01-06-2019 3:24 PM
01-06-2019 3:59 PM
Thanks for replying!
Currently the Broadband Fault Reporting and the chat services are unavailable. I also went through the Broadband Connection Troubleshooter but it didn't help. My connection has been extremely slow recently and keeps dropping, so I called the helpline and run some tests - the router was deemed to be faulty. I received new router, cables and filter from Plusnet yesterday but I keep having the same problems.
I am still unable to get in touch with anyone on the phone.
I wonder if there is a way to raise a ticket to the Faults team through this forum?
02-06-2019 1:37 PM
Hi @Tired,
I'm sorry that your new router hasn't resolved the connection problem and for the difficulty that you've had getting through to an advisor to report this.
I've reopened the fault ticket on your account and the next step is to arrange an engineer visit so that this may be investigated further. Please can you reply to the ticket here with your availability for an engineer? If you get back in touch on here once you've done this we'll pick this back up and get your engineer booked for the earliest available suitable appointment slot.
02-06-2019 3:30 PM
Hi Emily, thanks for your reply.
I am not clear on why I will likely be charged for the engineer visit. The equipment is brand new so I exclude it is faulty and there have been no building or garden works in the vicinity, so I expect no fault will be found - which means I will have to pay 65£ on top of the monthly fee, for a malfunctioning service!
When I called earlier this week I was told the problem could be fixed by installing a new router, so I renewed my contract in order not to be charged for that. If I knew this was not the cause, I would have likely moved to another broadband provider!
03-06-2019 9:53 AM
Thanks for getting back to us.
Sorry for any concern caused by a possible call out charge.
As we can see your connection is dropping it's unlikely the engineer will find no fault with your service, however if that was to happen and thing remained the same then we'll likely simply arrange another engineer to investigate further.
Engineer charges aren't something we take lightly and we review these within 90 days following a fault investigation closing. We will only apply a call out charge to your account if absolutely valid.
03-06-2019 10:21 AM
03-06-2019 12:12 PM - edited 03-06-2019 12:13 PM
04-06-2019 3:42 PM
Thanks! The engineer came by earlier today and was able to fix a line fault - my connection is now stable but still extremely slow (around 0.2 mbps!) I'm now waiting to hear back from the Faults team.
04-06-2019 4:22 PM
Hi @Tired, thanks for confirming everything has been cleared by the engineer. I've reset your line following the visit as it's likely your connection was banded as a result of the fault.
Effectively, the line management settings sacrifice speed in favour of stability. Without the connection issue being resolved, DLM will keep dropping your speeds.
In time this would normally adjust itself now that your line is stable but the reset should speed things up for you.
I've updated your fault ticket HERE with further details.
Should you need anything further, please feel free to get back in touch.
