Unable to log into router!
- Re: Unable to log into router!
19-04-2013 3:03 PM
Not sure what's happening but for some reason I can no longer get into my plusnet router, I put in my username and the password and it says its wrong O.o same username I use when logging into this site and same password so no idea why its not working maybe im doing something wrong? I was able to get into it before.
Message 1 of 5
(929 Views)
4 REPLIES 4
19-04-2013 3:05 PM
I guess this is for logging in to the router? If you didn't change it, the username is by default admin and the password is the one on the bottom of the router.
If you did change it, I'm not sure what's happened - did someone factory reset it, or have you reflashed it with a new firmware version? Either of those would change the username and password used to log in to the router's config pages back to the default ones above.
Hope that helps.
Hope that helps.
Message 2 of 5
(589 Views)
19-04-2013 3:07 PM
Nevermind I was able to log in, username is admin and got it sorted lol sorry.
Message 3 of 5
(589 Views)
19-04-2013 3:10 PM
Did you read "the username is by default admin and the password is the one on the bottom of the router" ?
(If you have never changed it then you should be able to login. Old versions of IE used to block logins, you try a different browser)
Message 4 of 5
(589 Views)
19-04-2013 3:35 PM
Glad you got it sorted out, thanks for letting us know
Please give us a shout if there's anything else we can do for you.
Message 5 of 5
(589 Views)
