Unable to log into portal.metronet
TooManyPies
I am unable to log into the metronet portal site even though it confirmed I was using the correct username and password when I selected the password reminder.  Is there a general problem?  I'm not sure if it's wise to mention my username here rather than pm a PN rep.
Oliver
Fixes: 162
Re: Unable to log into portal.metronet
I've just raised an internal problem on this, I'll get your name added as an example so we can push the priority.
 Chris Parr
 Plusnet Staff
Fixes: 162
Raised as a P1 now, you can find it here:-
http://portal.metronet.co.uk/support/service/problems/problem.php?intProblemId=51602
 Chris Parr
 Plusnet Staff
pierre_pierre
Chris, is the user cant log onto the Metronet portal, how can they look at your P1 on the Metronet portal  Crazy
Fixes: 162
Because you don't need to be logged in to see the problems on the portal Wink
 Chris Parr
 Plusnet Staff
TooManyPies
It's working now when I got home. Thanks.
