Unable to log into portal.metronet
TooManyPies
I am unable to log into the metronet portal site even though it confirmed I was using the correct username and password when I selected the password reminder.  Is there a general problem?  I'm not sure if it's wise to mention my username here rather than pm a PN rep.
Oliver
5 REPLIES 5
Chris
Legend
Fixes: 169
Re: Unable to log into portal.metronet
I've just raised an internal problem on this, I'll get your name added as an example so we can push the priority.
Chris
Legend
Fixes: 169
Raised as a P1 now, you can find it here:-
http://portal.metronet.co.uk/support/service/problems/problem.php?intProblemId=51602
pierre_pierre
Chris, is the user cant log onto the Metronet portal, how can they look at your P1 on the Metronet portal  Crazy
Chris
Legend
Fixes: 169
Because you don't need to be logged in to see the problems on the portal Wink
TooManyPies
It's working now when I got home. Thanks.
