Unable to connect to the office network via VPN, need PNP/VPN Trucking enabled
honeytrippers
Wondered if anyone can help.
Just switch from SKY to PlusNet for the static IP address today, but I'm unable to  connect to the office network via VPN.
Have spoken to the IT Team at work and they inform me that....
"you need your ISP to ensure the routing for PNP is enabled, PlusNet are known to not enable VPN trucking as standard."
Have spoken to the Technical Support on the phone and the poor guys had no idea what I was talking about.
Thanks in advance
Regards,
Keith.
9 REPLIES 9
pjmarsh
Fixes: 20
Re: Unable to connect to the office network via VPN, need PNP/VPN Trucking enabled
I've never heard it put like that before!  My only suggestion would be to see if the Broadband Firewall is blocking it.  I think you'd need it set to "Low" for VPN to work.  I can't remember what the default is on new accounts now.
Fixes: 393
Do you actually have a static IP ?
If its a residential account, then you need to request one and pay the one-off £5
If its business account , then I think you still need to request one but its free.
Some VPN implementations don't seem to like some of the public IP ranges that PlusNet use for dynamic IP's
Sounds like rubbish to me...
honeytrippers
Hi Pjmarsh,
Thanks for the reply
I turned off the firewall no joy.
honeytrippers
Hi MisterW,
Yer, paid the £5 for a static IP address for my home account.
I suspect the PNP/VPN trucking is the issue, as when I connect to the VPN successfully,but have no internet or network connectivity through it and the VPN remands connected, when I disconnect the VPN  internet/network returns.
The VPN as worked fine for the last year or so on the SKY broadband as well as for the other 60/70 employees using it every day, so don't think it's anything at the office end.
I previous encountered problems for other issues, like with the uses of PPP and PPPoE where the setting of the wrong protocols prevents access.
Protech
Fixes: 5
@honeytrippers you may need to reboot the router, or drop and reconnect the connection to enable the firewall changes to take effect, I have had to do that in the past .
Just to add I've been using various VPNs with Plusnet both on ADSL/VDSL for over a decade without needing any changes to be made by the ISP. However I have had to enable port clamping on some routers, there are multiple ways to set up VPNs .
It may help to get the exact settings required for the VPN from your IT department to see if you need to make any changes to your router, local firewalls or client configuration.
You can check out but you can never leave ( easily)
Fixes: 393
You also need to drop and reconnect to get the static IP allocated.
Never heard of it! Like @Protech ive been running VPNs over the PN network for years.
honeytrippers
Hi everyone
Thanks for the replies and the tip on rebooting the hub for the firewall settings to take effect.
It was the firewall, once it was disabled, I had network access on the VPN.
The only question is, what are the possible consequences of having the firewall disabled on the router?
Regards,
Keith.
Fixes: 393
Its not the firewall on the router, that's still enabled. Its a supplementary Firewall on the PlusNet gateway, that allows you to prevent any unsolicited incoming traffic even reaching your router. Problem is that when running a VPN, certain traffic needs to be allowed
Aspiring Hero
Fixes: 73
Hi @honeytrippers
For clarity the firewall being referred to is here ---> https://www.plus.net/member-centre/broadband/firewall
Dan.
