Unable to connect to company VPN
- Re: Unable to connect to company VPN
- « Previous
- 1
- 2
- Next »
29-12-2013 11:13 PM
Yes, same result. Cannot connect to site. Looks like I'm going to have to leave plusnet.
Message 16 of 19
(2,454 Views)
29-12-2013 11:27 PM
Have you tried alternate DNS servers or a different router
Message 17 of 19
(2,454 Views)
30-12-2013 9:41 AM
I have not tried different dns servers, I can try that later. I have taken the router out of the equation by connecting straight to the fibre modem.
Message 18 of 19
(2,454 Views)
30-12-2013 12:01 PM
In post #2 you said the firewall is set to standard, have you tried disabling it?
Have you looked at the link provided by avatastic in post #6. There's a workaround there to test if BT's modem is the problem.
Message 19 of 19
(2,454 Views)
- « Previous
- 1
- 2
- Next »
