Unable to access virginwines.co.uk
Llamas
Today I am unable to access the Virgin Wines website from my Plusnet connection.  However, I am able to access it via my work VPN and on my mobile phone.
Traceroute shows the break is somewhere beyond the Plusnet network.  Please can you have a word with the relevant provider?
$ tracert www.virginwines.co.uk
Tracing route to www.virginwines.co.uk [213.35.2.255]
over a maximum of 30 hops:
  1     2 ms     3 ms     2 ms  192.168.0.1
  2    17 ms    15 ms    18 ms  <snipped>
  3    15 ms    16 ms    15 ms  172.17.4.190
  4    21 ms    41 ms    22 ms  172.17.10.226
  5    22 ms    23 ms    22 ms  be2.pcn-ir02.plus.net [195.166.129.166]
  6    22 ms    23 ms    25 ms  195.99.125.144
  7    24 ms    24 ms    23 ms  195.99.127.66
  8    23 ms    23 ms    22 ms  213.137.183.102
  9     *        *        *     Request timed out.
 10    40 ms    24 ms    30 ms  NAVISITE-IN.ear2.London2.Level3.net [195.50.118.194]
 11    23 ms    23 ms    24 ms  62.32.103.143
 12    28 ms    25 ms    25 ms  62.32.103.155
 13    24 ms    24 ms    24 ms  213.35.0.167
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
Fixes: 33
Re: Unable to access virginwines.co.uk
It looks like it was an issue with a transit provider we use. We've not been able to replicate the issue here so let us know if that's still a problem for you.
 Adam Walker
Fixes: 19
Adam,
Is there a need to replicate? Do PN not have test processes for checking out such infrastructure? I note there's a topic over on the mail forum having similar symptoms ... but inbound to pop3.plus.net ... the trace dies in transit ... on the edge of BT's network.
Llamas
Thanks for the reply, but the fault is still happening...
  1     2 ms     1 ms     2 ms  192.168.0.1
  2    16 ms    17 ms    15 ms  <snip>
  3    16 ms    15 ms    16 ms  172.17.4.190
  4    22 ms    23 ms    22 ms  172.17.10.226
  5    24 ms    23 ms    21 ms  be2.pcn-ir02.plus.net [195.166.129.166]
  6    22 ms    22 ms    21 ms  195.99.125.144
  7    24 ms    23 ms    24 ms  195.99.127.66
  8    23 ms    21 ms    23 ms  213.137.183.102
  9    24 ms    23 ms    22 ms  10-1-1.ear2.London2.Level3.net [212.187.139.177]
 10    24 ms    24 ms    24 ms  NAVISITE-IN.ear2.London2.Level3.net [195.50.118.194]
 11    41 ms    30 ms    29 ms  62.32.103.143
 12    24 ms    24 ms    23 ms  62.32.103.155
 13    27 ms    24 ms    24 ms  213.35.0.167
Fixes: 19
Hmm...
Having revisited this on my PC (instead of trying to read the detail on my phone) I note that the non-responsive hops are WITHIN the target IP address space...
  • Target 213.35.2.255
  • End of responses 213.35.0.167
It would not be unreasonable for servers along the path to not respond to ping probes.  I cannot get ping responses from the URL or IP address ... but I can connect to the website.  Non-response on pings here is not a factor in the problem being experienced.
Need to consider the possibility of age restricted browsing safe guarding.
Also http://www.virginwines.co.uk redirects to https://www.virginwines.co.uk - so you should also consider redirection inhibition as a potential cause.
Llamas
Thanks. They do seem to be blocking my PC.  It's not browser-specific, as Firefox, Chrome and IE all get blocked, but using a different PC I can get in no problem.   Odd.
Thanks for pointing me in the right direction.
Fixes: 19
Given the additional information I'd be looking at AV software and / or cookies.
I do not see how a website can block a specific PC within your local network - your external IP address may be, but not an internal device.
