Unable to access virginwines.co.uk
FIXED- Subscribe to RSS Feed
- Re: Unable to access virginwines.co.uk
22-10-2017 7:03 PM
Today I am unable to access the Virgin Wines website from my Plusnet connection. However, I am able to access it via my work VPN and on my mobile phone.
Traceroute shows the break is somewhere beyond the Plusnet network. Please can you have a word with the relevant provider?
$ tracert www.virginwines.co.uk
Tracing route to www.virginwines.co.uk [213.35.2.255]
over a maximum of 30 hops:
1 2 ms 3 ms 2 ms 192.168.0.1
2 17 ms 15 ms 18 ms <snipped>
3 15 ms 16 ms 15 ms 172.17.4.190
4 21 ms 41 ms 22 ms 172.17.10.226
5 22 ms 23 ms 22 ms be2.pcn-ir02.plus.net [195.166.129.166]
6 22 ms 23 ms 25 ms 195.99.125.144
7 24 ms 24 ms 23 ms 195.99.127.66
8 23 ms 23 ms 22 ms 213.137.183.102
9 * * * Request timed out.
10 40 ms 24 ms 30 ms NAVISITE-IN.ear2.London2.Level3.net [195.50.118.194]
11 23 ms 23 ms 24 ms 62.32.103.143
12 28 ms 25 ms 25 ms 62.32.103.155
13 24 ms 24 ms 24 ms 213.35.0.167
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
Fixed! Go to the fix.
24-10-2017 2:30 PM
25-10-2017 10:10 AM
Is there a need to replicate? Do PN not have test processes for checking out such infrastructure? I note there's a topic over on the mail forum having similar symptoms ... but inbound to pop3.plus.net ... the trace dies in transit ... on the edge of BT's network.
25-10-2017 10:23 AM
Thanks for the reply, but the fault is still happening...
1 2 ms 1 ms 2 ms 192.168.0.1
2 16 ms 17 ms 15 ms <snip>
3 16 ms 15 ms 16 ms 172.17.4.190
4 22 ms 23 ms 22 ms 172.17.10.226
5 24 ms 23 ms 21 ms be2.pcn-ir02.plus.net [195.166.129.166]
6 22 ms 22 ms 21 ms 195.99.125.144
7 24 ms 23 ms 24 ms 195.99.127.66
8 23 ms 21 ms 23 ms 213.137.183.102
9 24 ms 23 ms 22 ms 10-1-1.ear2.London2.Level3.net [212.187.139.177]
10 24 ms 24 ms 24 ms NAVISITE-IN.ear2.London2.Level3.net [195.50.118.194]
11 41 ms 30 ms 29 ms 62.32.103.143
12 24 ms 24 ms 23 ms 62.32.103.155
13 27 ms 24 ms 24 ms 213.35.0.167
25-10-2017 11:59 AM - edited 25-10-2017 12:02 PM
Hmm...
Having revisited this on my PC (instead of trying to read the detail on my phone) I note that the non-responsive hops are WITHIN the target IP address space...
- Target 213.35.2.255
- End of responses 213.35.0.167
It would not be unreasonable for servers along the path to not respond to ping probes. I cannot get ping responses from the URL or IP address ... but I can connect to the website. Non-response on pings here is not a factor in the problem being experienced.
Need to consider the possibility of age restricted browsing safe guarding.
Also http://www.virginwines.co.uk redirects to https://www.virginwines.co.uk - so you should also consider redirection inhibition as a potential cause.
25-10-2017 2:02 PM
Thanks. They do seem to be blocking my PC. It's not browser-specific, as Firefox, Chrome and IE all get blocked, but using a different PC I can get in no problem. Odd.
Thanks for pointing me in the right direction.
25-10-2017 2:47 PM
I do not see how a website can block a specific PC within your local network - your external IP address may be, but not an internal device.
