Unable to access Brent Council
- Re: Unable to access Brent Council
09-08-2016 10:26 PM
Hello,
I am unable to access the Brent council web site using Plunet. I am able to connect from other (non Plusnet) locations or using my mobile data.
It may not be a very exciting site, but I need to be able to book parking places and so on.
Why should this be so? Why only Plusnet? Surely Brent hasn't been caught up in some kind of filter (porn or spam).
Help please
Thanks.
09-08-2016 11:34 PM - edited 09-08-2016 11:35 PM
Try obtaining a new Plusnet IP address - your current one might be blacklisted.
Using your router admin signin,
1. Disconnect the internet connection.
2. Wait a couple of seconds
3. Reconnect to the internet.
Alternatively, provided you are getting a good speed from Plusnet,
You could just switch your router off for 30 seconds, then on again.
Don't do this more than once an hour though.
10-08-2016 11:49 AM
Thanks for the reply.
I've changed the IP address using ipconfig/release and ipconfig/renew. But still can't get through to Brent
I've also tried disactivating the Plusnet porn filter (just in case Brent is considered porn!).
Still no change.
10-08-2016 12:23 PM
Hi salvadorfreeman,
OK what you need to do it to contact webteam@brent.gov.uk and explain your issue with viewing the site. when contacting about website advise them that your IP address is 51.6.86.96 and they should be able to resolve this for you.
