Un cap upload speed & turn interleaving off.
wiganfcfan07
I only use broadband for gaming and having a high ping and a capped upload speed isn't helping.
Would it be possible to have interleaving turned off and the upload speed uncapped?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Un cap upload speed & turn interleaving off.
Hi wiganfcfan07,
Your upload speeds should already be uncapped on an FTTC connection. what sort of speeds and pings are you seeing?
Chris Pettitt
Cloud Environments Engineer
wiganfcfan07
Hi Chriss, some days it's 18mb upload and less then 10 ping(Which is perfect) and other days 2mb upload and 160+ping to the same servers ect. Not sure if it's due to interleaving on or just a poor line idk. Any help would be great. Thanks
jim:quote
deejayburnout
i have only a 0.44mb upload speed and my ping is fine. i would expect 2mb to be fine also.
What games are you playingHuh
wiganfcfan07
Can anything be done? As having a different internet connection each day is very frustrating, could you at least let me know if interleaving is on or off?
thanks
Fixes: 10
I'm guessing you are using a wireless connection to the router - correct? If that is the case have you checked the speed and latency wired?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
wiganfcfan07
No, I only use wired. I have wifi not enabled...
All4One
How many other people use the connection?
Plusnet Staff
Plusnet Staff
Fixes: 5
@ wiganfcfan07 - what servers are you connecting to when you get the low speeds?
Chris Pettitt
Fixes: 163
Looks like substantial uploads on the 16th, 18th and 20th. Did you have a backup running or similar on those days?
The amount of upload usage would certainly explain the ping you were seeing, especially in the short timeframe it was happening (mainly peak time in the evenings)
 Chris Parr
 Plusnet Staff
wiganfcfan07
Ok thanks Chriss i will try not to download anything for a while and then test for a few days afterwards to see if it's that. I will update, then.
Fixes: 163
Sorry, I wasn't clear. The ping is going to be high during the periods you're uploading.
 Chris Parr
 Plusnet Staff
Fixes: 10
@wiganfcfan07
Are you running P2P software? If so and you haven't restricted the upload speed your connection will be knackered even when you are not downloading.
wiganfcfan07
I found the problem, i turned game mode off. Ping has improved considerably and also more stable(In terms of it not spiking).
Thanks for the advice and tips this can now be deleted/locked.(Not sure on the rules for this forum)...
