Un cap my up load ..switch to fastpath Please
waynem
Hi as it says above , could a Kind PN employee please uncap my upload and switch me to fast path ...
thanks
9 REPLIES 9
jelv
Fixes: 10
Re: Un cap my up load ..switch to fastpath Please
Just looked through your previous posts and it appears your upstream is already uncapped. Could you post your stats from the router please?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
waynem
i did have it uncapped when i first started with PN ... then it got capped  at 800  or whatever is  ... when it was switched to interleaved
jelv
Fixes: 10
If it were capped it would be 448 or lower.
waynem
Hi again ...thats not the information received from PN .... they said that when switching back from fast path to interleaved  ..upload is automatically capped at 888  ..
and i would like it uncapped and set back to fastpath .
thanks
Chris
Legend
Fixes: 169
Yes, but that's not a separate cap, that's just a side effect of interleaving.
waynem
Hi chris ...
yeh i understand that ... which is why  iam asking to have fastpath switched back on .
thanks
Chris
Legend
Fixes: 169
I was just getting someone to place the order to do that! Should complete tomorrow.
adamwalker
Fixes: 221
Sorted, order 1-14189517717 is in place to remove interleaving tomorrow.
 Adam Walker
waynem
Thanks very Much chris  and Adam  .... any updates  to the fibre situation ... openreach were here again last week  linking the cabinets Huh
iany info you can give me will be much appreciated
cheers Grin
