Ultra Slow
DonaldDuck
Ultra Slow
I live down a private road and was getting  330k maximum download day or night which is about 6 youtube vids at 720p any more and they start buffering and hanging. If I use Netflix then forget about anything else I got a pretty good router with bandwidth monitor. I called in and they said they made some adjustments and now I have a lightning speed of 380k Is this a joke ?
Funny how when I call up they always try to sell me fibre but there's no way they can get fibre down here as the green box is about a mile away
19 REPLIES 19
Legend
Fixes: 246
Re: Ultra Slow
Can you post your router statistics - then we may be able to help you
DonaldDuck
Re: Ultra Slow
On
On
SNR Margin
8.0 dB
11.0 dB
Line Attenuation
63.5 dB
31.5 dB
Path Mode
Interleaved
Interleaved
Interleave Depth
16
4
Data Rate
3392 kbps
640 kbps
Max Rate
3680 kbps
812 kbps
Power
18.0 dbm
12.0 dbm
INP
2.0 symbols
2.4 symbols
Legend
Fixes: 246
Re: Ultra Slow
Also, it would be helpful to see details from these two links:
https://www.broadbandchecker.btwholesale.com/#/ADSL - obscure/hide your phone number
https://speedtest.btwholesale.com/ - please complete the advanced test.
Legend
Fixes: 246
Re: Ultra Slow
From your router stats, you are getting about as good as you can, given the reported line attenuation, and FTTC, if the cab is that far away, wouldn't be a good idea.
Your line is interleaved, presumably to try and alleviate the errors which have caused your SNR to rise (and reduce the download rate), but one strange issue is the level of upstream SNR - I don't understand the reason for that.
DonaldDuck
Re: Ultra Slow
Advance Test
Download Test
Download speed achieved during the test was 2.77 Mbps
For your connection, the acceptable range of speeds is 1.2 - 4 Mbps
IP Profile for your line is 2.99 Mbps
2.77 Mbps
4 Mbps
Upload Test
Upload speed achieved during the test was 0.68 Mbps
IP Profile for your line is 0.83 Mbps
0.68 Mbps
0.83 Mbps
DonaldDuck
Re: Ultra Slow
Putting all the tech aside I'm very suspicious about the pure straight line on my download speed monitor. If was just the length of line to the cab and some other electrical anomolies the data rate would rise and fall especially in the middle of the night.
I suspect there is a data cap in place. It does the exact same amount 24/7 when I'm downloading files and when I'm not downloading a lot it just fluctuates as normal below the maximum line
Legend
Fixes: 246
Re: Ultra Slow
Your test results look about right, given the SNR figures quoted, but the results of the other link I posted would be useful, please.
Are red figures inserted by you, to suggest you expect them? - if so, I'm sorry  but they are the max possible on a clean line, which yours isn't.
Legend
Fixes: 246
Re: Ultra Slow
OK, can we see a screen grab of your data monitor - and it would fall, rather than rise in the middle of the night, due to icreased electrical activity. There is no data cap - just being on a very marginal line.
DonaldDuck
Re: Ultra Slow
I just copy pasted the results which came out in red
the speed test showed 2.77 Mb on the download
Legend
Fixes: 246
Re: Ultra Slow
OK - it is a while since I've run that test, can't remember exactly what i looks like.
DonaldDuck
Re: Ultra Slow
The line tests and speed checker say that the line can handle some speed in theory. The straight line (ceiling) on the traffic monitor says something else to me. Run 6 Youtube vids =330KB run 20 Youtube vids buffering =330KB  day or night -no spikes it just flat lines like it's on a rev limiter
Legend
Fixes: 246
Re: Ultra Slow
OK, but as I've said, you are on a marginal, impacted, line which will have a detrimental effect on performance. Which line tests and checker are you talking about? And without seeing the traffic monitor I can't really comment, although based on the figures you have provided, as I said, you are getting as good as you will.
I am assuming you are somewhere 'out in the wilds' as it were, and I'm also guessing your exchange is some distance away, and you are fed by overhead wires?
EDIT - are you sure the traffic monitor is performing correctly?
DonaldDuck
Re: Ultra Slow
The exchange is about 3 mile away and the Cab about 1 mile. I checked the download rate with ProtonVPN which also has a traffic monitor which shows the same flat line and I also have two PCs next to each other so I can run some bandwidth through the VPN and some not - all the data correlates. Seems funny that they are confident in selling me on the fibre upgrade yet I don't see how they could possibly improve the situation using the same lines if they can't get me 1Mb.how they going to get me 15Mb which is what they said  I'm out of contract so I'll have a shop around and see if my download speed suddenly mysteriously improves
Legend
Fixes: 246
Re: Ultra Slow
OK, you have answered nearly all my questions, so I'll give up asking for those you haven't - as a point of interest, FTTC and ADSL are different animals, so behave differently, but based on the data provided, irrespective of who you go with as an ISP, the signals will still all come down the same wires, and you will get very similar speeds.
