Ubiquiti EdgeRouter Lite Config
PLan
Just purchased an EdgeRouter Lite and have a config that works with FTTC and Plusnet - hopefully this config will get you up and running quickly if you buy the same router. In this script eth0 becomes the WAN port, eth1 and 2 are bridged and act like a switch. Router at 192.168.1.1, DHCP addresses at 192.168.1.100-200.  I installed this immediately after upgrading the firmware and before adding users - edit to include your login details and cut and paste into your router's config(see "Tips For Rolling Your Own Config"). You can enter Plusnet's name servers if you want ...  Shocked
firewall {
   all-ping enable
   broadcast-ping disable
   conntrack-expect-table-size 4096
   conntrack-hash-size 4096
   conntrack-table-size 32768
   conntrack-tcp-loose enable
   ipv6-receive-redirects disable
   ipv6-src-route disable
   ip-src-route disable
   log-martians enable
   modify pppoe-out {
       description "TCP clamping"
       rule 1 {
           action modify
           modify {
               tcp-mss 1452
           protocol tcp
           tcp {
               flags SYN
   name pppoe-in {
       default-action drop
       description "Internet to internal networks"
       rule 1 {
           action accept
           description "Allow established/related"
           log disable
           state {
               established enable
               related enable
       rule 2 {
           action drop
           description "Drop invalid state"
           log enable
           state {
               invalid enable
   name pppoe-local {
       default-action drop
       description "Internet to router"
       rule 1 {
           action accept
           log disable
           state {
               established enable
               related enable
       rule 2 {
           action drop
           log enable
           state {
               invalid enable
       rule 5 {
           action accept
           description "ICMP 50/m"
           limit {
               burst 1
               rate 50/minute
           log enable
           protocol icmp
   send-redirects enable
   source-validation disable
   syn-cookies enable
interfaces {
bridge br0 {
address 192.168.1.1/24
   ethernet eth0 {
       duplex auto
       pppoe 0 {
           default-route auto
           firewall {
               in {
                   name pppoe-in
               local {
                   name pppoe-local
               out {
                   modify pppoe-out
           mtu 1492
           name-server auto
           password yourpassword
           user-id userid@plusdsl.net
       speed auto
   ethernet eth1 {
       bridge-group {
           bridge br0
       description LAN
   ethernet eth2 {
       bridge-group {
           bridge br0
       description LAN2
   loopback lo {
service {
   dhcp-server {
       disabled false
       shared-network-name LAN-Subnet {
           authoritative disable
           subnet 192.168.1.0/24 {
               default-router 192.168.1.1
               dns-server 192.168.1.1
               lease 86400
               start 192.168.1.100 {
                   stop 192.168.1.200
   dns {
       forwarding {
           cache-size 150
           listen-on br0
        system
   gui {
       https-port 443
       listen-address 192.168.1.1
   nat {
       rule 5010 {
           log disable
           outbound-interface pppoe0
           protocol all
           type masquerade
   ssh {
       port 22
       protocol-version v2
system {
   host-name ubnt
   ipv6 {
       disable
   login {
       user ubnt {
           authentication {
               encrypted-password $1$zKNoUbAo$gomzUbYvgyUMcD436Wo66.
           level admin
   name-server 8.8.8.8
   name-server 8.8.4.4
   ntp {
       server 0.ubnt.pool.ntp.org {
       server 1.ubnt.pool.ntp.org {
       server 2.ubnt.pool.ntp.org {
       server 3.ubnt.pool.ntp.org {
   syslog {
       global {
           facility all {
               level notice
           facility protocols {
               level debug
   time-zone UTC
