UTorrent problem
StephenF
UTorrent problem
i just wondered if you could help me and tell me wether or not the problem is on my end or if its blocked or something? i dont know.
Ive used utorrent for a good few years, i have all my ports correctly opened and firewall setup correctly, yet for some reason i am consistently getting "Connection closed by peer" and a red down arrow
no matter which torrent im downloading.
Just wondered if you could clarify its something on your end i know theres nothing i can do about it.
cheers
9 REPLIES 9
SparckZero
Re: UTorrent problem
StephenF,
Has this problem only started recently? Which Plusnet package are you on?
StephenF
unlimited,
and yes but not since changing to plusnet, i also had it with tiscali, however, id just like to make sure that its at my end first before i try replacing my router or wiping my os or something, as ive tried everything else and its, to be honest, starting to piss me off
VileReynard
Fixes: 20
Do you have firewall blocking at the plusnet end of things switched on?
See https://portal.plus.net/my.html?action=firewall&firewallPage=basic
Personally, I make this switched off
- but I wouldn't recommend this if you are running a Windows PC.
Fixes: 1,483
Within uTorrent there is an test to see if your ports are open, what does this say?
StephenF
firewall is off and it says the ports are open.
i have my own personal eset smart secruity firewall set up anyway Smiley
StephenF
any ideas?
VileReynard
Fixes: 20
Have you tried an alternative P2P client such as Vuze (which works for me) Cheesy
StephenF
working fine with vuze, thanks bud
do not understand why utorrent packed in though =/
VileReynard
Fixes: 20
Me too - in fact
My son uses uTorrent on Windows whilst I use vuze on Linux.
And they both work, simultaneously. Grin
