US IP Address
AlexanderJG90
US IP Address
Recently upgraded my broadband fibre product with Plusnet... and now all my connections think I live in the US!
If I check my IP address properly, it does display properly and things like BBC iPlayer work fine - but whenever I used google etc, I think I live in the US and I get US ocused search result
(This across all devices, so not settings based)
Any ideas on how to reset it back to UK?
Tags (2)
3 REPLIES 3
Fixes: 389
Re: US IP Address
The chances are that this ex an ex-BT Americas IP,  and the sites thinking you are U.S. based haven't updated their geo-location data, or are just using inefficient providers. I'm surprised Google is so way out though -  they at least usually get the country correct - but not always the city.
What other sites are misbehaving?
AlexanderJG90
Re: US IP Address
My main issue is why it's suddenly started.
Lived here 7 years, plusnet the last 4 years and just started doing it a couple of months ago.
Fixes: 389
Re: US IP Address
Probably because your external IP changed for some reason around that time. As I asked, what other sites are guilty of this, and what results do you get if you enter your IP into this site: My IP - What is my IP address? Free IP Tracer, IP Locator, Hide my IP address
