UPGRADE
cjc13
UPGRADE
hi all
a few days ago i took on the upgrade of 37 mb which now i see i just cant afford it
how to stop the order going through
2 REPLIES 2
Fixes: 365
Re: UPGRADE
You either need to ring in or use live chat to cancel it.
Fixes: 1,547
Re: UPGRADE
Hi there.
I'd recommend giving our customer options team a call on 0800 013 2632 as we may be able to do you a better deal.
Alternatively if you'd still like to cancel your upgrade, that team will be able to process this for you too.
Hope this helps.
