UKonline to Plusnet speed issue
siltshifter
Re: UKonline to Plusnet speed issue
An extension. The main BT socket does not look like the one in your picture, it is definitely somewhat older!
Problem: my main computer is connected to the router via ethernet cable and does not have a wireless option. The test socket I believe I have is some way away from where this computer is setup. I do have a laptop, however, and could consider setting that up so the router could be plugged in to the test socket.....but I would like to know for how long you would want me to stay connected in this way, please
jojopillo
HI siltshifter,
If you were to plug into the test socket we could run a test and tell straight away whether there was any improvement. I'd put money on it being the extension though, they can be notorious!
Jojo Smiley
siltshifter
Hello Jojo, I am now using the test socket. Readings are as follows:
Uptime: 0 days, 0:05:43
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 3,496
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,448
Data Transferred (Sent/Received) [kB/MB]: 772.00 / 1.06
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 29.5 / 51.0
SN Margin (Up/Down) [dB]: 21.0 / 9.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 64 / 1
HEC Errors (Up/Down): 14 / 1
And these readings appear to be even worse!
Please can you advise for how long the 'test' should run? There are cables all over the place at the moment and it's a bit of a mess.
jojopillo
HI siltshifter,
If it's not like the one in the picture then it's not the test socket. If you don't have one of them then you need to plug into the master socket with all other equipment unplugged. The master socket will be the one where the line enters the property. If that's not the case then I'd put it back where you had it and wait for the ip profile to lift.
Jojo Smiley
siltshifter
Hello Jojo, thanks for your patience.
Initially I probably had my phone base station too close to the router; I've moved them further apart now and wonder if that will make a difference.
Quote from: Joanne
If it's not like the one in the picture then it's not the test socket. Jojo Smiley
Attached are a couple of pictures that may help clarify whether or not it is a test socket.
Reading are currently:
Uptime: 0 days, 0:20:12
Maximum Bandwidth (Up/Down) [kbps/kbps]: 932 / 3,616
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,576
Data Transferred (Sent/Received) [kB/MB]: 449.00 / 1.56
Output Power (Up/Down) [dBm]: 12.5 / 16.5
SN Margin (Up/Down) [dB]: 23.0 / 9.5
Loss of Framing (Local/Remote): 65,597 / 0
Error Seconds (Local/Remote): 19 / 0
CRC Errors (Up/Down): 32 / 11
HEC Errors (Up/Down): 7 / 9
How about I leave as is for the weekend to see if the uptime position improves compared with all the resets I've seen over the last week/10 days?
All the best
David
jojopillo
Hi David,
Yes, from your pictures you are definitely in the test socket. From the connection logs below can you tell me whether any of the drops were intentional? If not I would certainly raise a fault. Are you able to try a different router?
Jojo Smiley
siltshifter
Hello Jojo, sorry for the delay - been out all day working on canal restoration!
I don't think you attached or enclosed the connection logs you refer to, but there have not been any intentional drops.
Yes I can try a different router (Thompson Gateway to Netgear) which I will do later this evening or tomorrow. Meanwhile my linespeed suddenly went up by 20% this morning; I have had the longest uptime since I started this post, currently 1 day 2 hours & 48 minutes! Previously it was resetting well within a 24-hour period and for no apparent reason.
A  BT Speedtester test I've just undertaken also shows an increase in my IP profile from 2500 Kbps (download speed 2130) on the 14th to  3,000Kbps and a speed of 3106.
In view of the increase in my linespeed would it make sense to leave this in abeyance for now, rather than raising a fault at this stage?
puddy
David
Why not fix a BT-i plate it’s also called  BT accelerator too  it should increase your download speed its worth a try for less than £10.  You can fit it to your master socket
Its only useful if you have any extension sockets in your house.
It’s also reduces your HEC CRC etc. mine still zero and it’s been connected for over 358:11:25
There’s no wiring involved at all
Puddy
siltshifter
Cheers Puddy - thanks for the tip.
I feel as if  I should know you, as you seem to know me...............
siltshifter
Stupid boy that I am - I now realise how you know my name!!
jojopillo
HI David,
Sorry forgot to post the logs, definitely will this time. Can you tell me of these disconnections which are intentional.
Jojo Smiley
siltshifter
Morning Jojo
The one today, whilst I changed Routers. Not one of the others was intentional.
Having swapped Routers, disconnected the bellwire and adjusted the positioning of the telephone base unit I am well pleased at the moment with speeds:
(Netgear stats)
DownStream Connection Speed 4371 kbps
UpStream Connection Speed 439 kbps
And a speed test is showing 2732kbps/375kbps.
If they all stay at around this level I shall be well pleased; as I said before, shall we let sleeping dogs lie for a few days just to see what happens?
D
jojopillo
HI siltshifter,
Your profile is now 3000 and from your sync it could rise to 3500, so as long as there aren't lots of disconnections this should go up soon.
Jojo Smiley
siltshifter
Thanks Jojo.
Fingers crossed that I don't have to trouble you again..........
jojopillo
Yes, I hope not... In a good way of course Smiley
