Type of connection
- Type of connection
Type of connection
22-08-2017 10:21 AM
A guy from Mcafee asked me the question:
What is the internet connection you have? (Dial-up, DSL, Cable, Cable-Wireless, DSL-wireless, Fiber-Optic, Satellite or T1/LAN) ?
Normally I just say wireless because I think that is all they need to know, But this one guy then said Cable-wireless or DSL-wireless. ?
As far as I'm concerned it is just wireless. The wire comes in the house to the router then I connect wirelessly.
So I can decide, can anyone enlighten me pls?
Re: Type of connection
22-08-2017 10:25 AM - edited 22-08-2017 10:26 AM
@candnwillis - The answer to that depends on your type of Broadband connection you're on, if it's ADSL or fibre then it would be the latter of the two, but if you were on Virgin Cable then it's the former.
HTH
22-08-2017 12:08 PM
So you're using wi-fi for your device(s) to connect to the router.
The McAfee guy is referring to your internet connection. If there's a wire coming into the house it isn't wireless.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
22-08-2017 12:09 PM
My cabling is and was nothing to do with Virgin. It's the old BT cable from post to outside wall, same as the house has had for many years. We just signed up for broadband and plugged in the router.
22-08-2017 12:10 PM
It is wireless from my laptop to the router though. what does that make it then pls ?
22-08-2017 12:13 PM
Our telephone line is one originally suited to telephone, not the internet so would that make us cable?
22-08-2017 12:22 PM - edited 22-08-2017 12:29 PM
It'll be DSL then.
'Cable' in this context means a service like Virgin's, where a coaxial cable runs from the operator's street cabinet to the home.
22-08-2017 12:27 PM
22-08-2017 12:33 PM - edited 22-08-2017 12:36 PM
Hi @candnwillis & welcome to the crazy world of techspeak!
At the risk of confusing you further BT Openreach supply two offerings FTTP where fiberopic cable is run to your house (property) and FTTC where fiberopic cable is run to the local cabinet and then the connection is made through the traditional telephone cable you have. Virgin do cable which looks like a coaxial cable and is run separately to your house. iIRC Virgin will also supply FTTC as well where they don't supply cable.
To be is to do - Kant
do be do be do - Sinatra
22-08-2017 12:42 PM
Ok, that sound near enough thx.
22-08-2017 12:42 PM
Thx
I bet that's a real gas ....
22-08-2017 1:33 PM
Er, what about ADSL ?
Virgin have never supplied FTTC AFIAA, they used to provide ADSL to customers outside their footprint but they sold that business to TalkTalk a few years ago
22-08-2017 1:36 PM
Virgin are actually rolling out FTTP in some areas then convert it back to Docsis or whatever in the house.
22-08-2017 1:49 PM - edited 22-08-2017 1:50 PM
That's what I call "Virgin on the ridiculous".
22-08-2017 1:54 PM
In the context of the options in McAfee's list, I would interpret DSL as being ADSL or VDSL (FTTC), and Fibre Optic as being FTTP/FTTH.
