Type of connection
candnwillis
Type of connection
A guy from Mcafee asked me the question:
What is the internet connection you have? (Dial-up, DSL, Cable, Cable-Wireless, DSL-wireless, Fiber-Optic, Satellite or T1/LAN) ?
Normally I just say wireless because I think that is all they need to know, But this one guy then said  Cable-wireless or DSL-wireless. ?
As far as I'm concerned it is just wireless. The wire comes in the house to the router then I connect wirelessly.
So I can decide, can anyone enlighten me pls?
17 REPLIES 17
Re: Type of connection
@candnwillis - The answer to that depends on your type of Broadband connection you're on, if it's ADSL or fibre then it would be the latter of the two, but if you were on Virgin Cable then it's the former.
HTH
198kHz
Fixes: 41
So you're using wi-fi for your device(s) to connect to the router.
The McAfee guy is referring to your internet connection. If there's a wire coming into the house it isn't wireless.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
candnwillis
My cabling is and was nothing to do with Virgin. It's the old BT cable from post to outside wall, same as the house has had for many years. We just signed up for broadband and plugged in the router.
candnwillis
It is wireless from my laptop to the router though. what does that make it then pls ?
candnwillis
Our telephone line is one originally suited to telephone, not the internet so would that make us cable?
198kHz
Fixes: 41
It'll be DSL then.
'Cable' in this context means a service like Virgin's, where a coaxial cable runs from the operator's street cabinet to the home.
Browni
Aspiring Hero
Fixes: 60
+1 for DSL.
PeterLoftus
Fixes: 5
Hi @candnwillis & welcome to the crazy world of techspeak!
At the risk of confusing you further BT Openreach supply two offerings FTTP where fiberopic cable is run to your house (property) and FTTC where fiberopic cable is run to the local cabinet and then the connection is made through the traditional telephone cable you have. Virgin do cable which looks like a coaxial cable and is run separately to your house. iIRC Virgin will also supply FTTC as well where they don't supply cable.
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
candnwillis
Ok, that sound near enough thx.
candnwillis
Thx
I bet that's a real gas ....
DaveyH
Champion
Fixes: 12
Er, what about ADSL ?
Virgin have never supplied FTTC AFIAA, they used to provide ADSL to customers outside their footprint but they sold that business to TalkTalk a few years ago
RealAleMadrid
Aspiring Hero
Fixes: 59
Virgin are actually rolling out FTTP in some areas then convert it back to Docsis or whatever in the house.
candnwillis
That's what I call "Virgin on the ridiculous".
198kHz
Fixes: 41
In the context of the options in McAfee's list, I would interpret DSL as being ADSL or VDSL (FTTC), and Fibre Optic as being FTTP/FTTH.
