Two months no internet, miniscule compensation and now pathetic speeds !!!
Povvercrazy
So my story starts in June 24, broadband went down but I was away for a month so didn't realise till I was home end of july.
Reported immediately to customer services, took them 8 weeks to be able to raise a fault with Openreach,
and when they finally came out couldn't find an issue, some one reset something Plusnet end and it seemed to fix it.
Hurrah!!! unfortunately I was away again for a month a few days after it was fixed.....
I came home last week and my internet speeds are appalling, between 3 - 18 Mbps and pings between 40-60
On a line that before June and ever since I was on FTTC would get pings of 10-12 and speeds of approx. 40 Mbps all day long!
I've also just noticed my account doesn't list a minimum guaranteed speed anymore ??
And where is my compensation for having two months with no broadband ? my only response is its automatic?
I've only had £29.28 payed into my account.
It just appears you no longer want me as a customer after over 10 years!
16 REPLIES 16
Fixes: 334
Re: Two months no internet, miniscule compensation and now pathetic speeds !!!
Which router are you using? There is obviously a fault, but knowing the answer to my question helps in replying.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
Povvercrazy
No phone line unfortunately,
It's a Hub 2, just very disheartened at the moment after the summer I've had with it all.
I did leave it a week to see if things would self correct.
Phone it is then
Fixes: 334
OK. In that case please follow the below.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'- if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Povvercrazy
Povvercrazy
The Additional Diagnostics on Btwholesale have always come up with cant do further diagnostics for some reason
Fixes: 334
Taking the status page into account with the BT Availability checker, you are below the Hand Back threshold and your SNR is too low. Call support and ask them to run tests.
Povvercrazy
Ty will do cheers
willcutforth
Fixes: 113
@Povvercrazy I have tested the line and there is an external fault for you. I have raised it to OR and it should be fixed in the next few days.
 Will Cutforth
Povvercrazy
Awesome Thank you, Was  just waiting for my mobile to charge up and ring you guys, cheers
willcutforth
Fixes: 113
No worries, let us know if you need anything else Smiley Won't be me after Sunday though as I am being re-deployed back to front line calls.
 Will Cutforth
Fixes: 334
That's a shame, @willcutforth . Who is your replacement?
willcutforth
Fixes: 113
@jab1 it will be a full new team for you who are trained in Early Life, Tech and Billing so they can cover all bases. Email support might not be their strong suit just to forewarn.
 Will Cutforth
Fixes: 334
@willcutforth Cheers. Just so long as they are as good as you, we shouldn't have any problems. 😀 . Email  might not be a problem, there a couple of Super Users with a great deal more knowledge than me. I get lost with Windows programs as I've not used them for about 25 years.
willcutforth
Fixes: 113
@jab1 You guys have saved us no end over the years and that has helped us out! You'll get an influx of people who call up, on here as I will start recommending them 😀
 Will Cutforth
