Twitter
21-07-2015 7:38 PM
Any suggestions?
Re: Twitter
21-07-2015 7:45 PM
Re: Twitter
21-07-2015 7:50 PM
Router is a Thomson TG 585
I tested my speeds and I appear to be only getting upload speeds of 0.03Mbps - might this be a contributory factor? Download is 3.29Mbps at about 19:00 hrs
Re: Twitter
21-07-2015 8:04 PM
Can you connect a pc via a cable and test the speed using that.
Re: Twitter
21-07-2015 8:29 PM
Re: Twitter
21-07-2015 8:31 PM
Re: Twitter
22-07-2015 9:27 AM
Connection speeds are fine, the connection isn't dropping much. No errors on the line and the line quality is green.
Sync speeds
Down: 8128
Up: 448
Can you try a BT Speedtest at http://speedtest.btwholesale.com/ going through to the 'further diagnostics' after the first test and let us know the results.
Re: Twitter
22-07-2015 12:46 PM
Re: Twitter
22-07-2015 12:48 PM
Re: Twitter
22-07-2015 12:59 PM
download = 6.84
upload = 0.02
ping latecy = 153.63
DSL connection rate = 8.13 down, 0.45 up
IP profile = 7.15
generally, i have no problem with speeds for what I need to do, or with downtime or service dropping. But Twitter simply will not send a post with a photo! and my continuous online backup service (used for nearly 10 years without any problem) has stopped working too
Re: Twitter
22-07-2015 1:30 PM
Re: Twitter
22-07-2015 1:39 PM
Quote from: Chilton1199 how do I find out if I have a wireless adapter, and how do I turn it off?
What is the make/model of your laptop?
Re: Twitter
22-07-2015 1:43 PM
Re: Twitter
22-07-2015 3:23 PM
start> control panel > system > device manager > network adapter lokk for something like xxxxxxxxwireless?
click on xxxxxxxxwireless? and should come up with a box that has properties at the top
click properties then look for disable.
If you get stuck just come back and say so
Re: Twitter
22-07-2015 4:11 PM
