Turning off wifi but not the router itself
slinks
Hi
Just wondered if there is anyway of disabling wifi without having to turn the router off completely?
Many thanks
Jac
Fixes: 62
Re: Turning off wifi but not the router itself
http://192.168.1.254/cgi/b/lan/?be=0&l0=4&l1=-1
Click on the Wireless LAN then Configure  and untick Interface Enabled
slinks
Cheers for that, though I don't think my kids will thank you as much!  Wink
Fixes: 4
If they are smart, they will use the reset button when you go shopping  Grin
Fixes: 46
If its a standard TG582n then there is a Wifi button on the top of the router, short press turns it ON , long press ( hold until light goes out ) turns it OFF.
I won't tell the kids about it if you don't Wink
slinks
Wow MisterW brilliant that's a much simpler solution! I am honestly only thinking of the welfare of my two step daughters (12 and 15)......... They cannot get a signal on their phones so wifi is their only way of communicating until the early hours, the little darlings  Roll eyes  I am not an evil step mum ...honest  Lips are sealed
