Turning off wifi but not the router itself
- Re: Turning off wifi but not the router itself
21-07-2013 11:51 AM
Hi
Just wondered if there is anyway of disabling wifi without having to turn the router off completely?
Many thanks
Jac
Many thanks
Jac
Message 1 of 6
(1,138 Views)
5 REPLIES 5
21-07-2013 11:54 AM
http://192.168.1.254/cgi/b/lan/?be=0&l0=4&l1=-1
Click on the Wireless LAN then Configure and untick Interface Enabled
Message 2 of 6
(637 Views)
21-07-2013 12:54 PM
Cheers for that, though I don't think my kids will thank you as much!
Message 3 of 6
(637 Views)
21-07-2013 12:59 PM
If they are smart, they will use the reset button when you go shopping
Message 4 of 6
(637 Views)
21-07-2013 1:30 PM
If its a standard TG582n then there is a Wifi button on the top of the router, short press turns it ON , long press ( hold until light goes out ) turns it OFF.
Quote Just wondered if there is anyway of disabling wifi without having to turn the router off completely?
I won't tell the kids about it if you don't
Message 5 of 6
(637 Views)
23-07-2013 9:39 AM
Wow MisterW brilliant that's a much simpler solution! I am honestly only thinking of the welfare of my two step daughters (12 and 15)......... They cannot get a signal on their phones so wifi is their only way of communicating until the early hours, the little darlings I am not an evil step mum ...honest
Message 6 of 6
(637 Views)
