Turning off Wireless router overnight
- Turning off Wireless router overnight
- « Previous
- 1
- 2
- Next »
Re: Turning off Wireless router overnight
13-02-2008 9:41 PM
(Oh and btw, I'm a she )
13-02-2008 10:30 PM
I have heard of people putting routers in their loft to get the equipment out of reach.
Out of interest, have you tried changing your wireless frequency to the other end of the scale regarding headaches? I have a separate Wirless access point connected to a router so turning wireless off is very simple - unplug it!
14-02-2008 12:01 AM
flicker - Looking back at the original post, I'm just wondering why you don't use an extension lead to move the router? The reason you give for it being over your head is that this is close to where the socket is - is that the obly thing preventing you from moving it?
Two days without headaches is not quite conclusive proof, but very interesting all the same. Maybe not getting microwaved all night is a good idea?!
14-02-2008 8:42 AM
So maybe yesterday was just a glitch because I believe it takes longer for BT to alter it back?
Anyway, out of interest, without moving my position at all (I'm still in bed ) I just plugged in the ethernet cable, and disabled the wireless connection and got -
Now I have in the past tried moving the router to all different positions, moving the aerial etc, but still can never get anything like the same speeds using wireless as with ethernet. Any tips therefore as to what I can do, as obviously, most of the time, I use it wirelessly, as I am in a different room to the router, and I don't want cables hanging from the sky etc!
(And to answer the question, yes it is because the cable is only long enough to have the router where it is at present, within a few feet or so anyway.)
14-02-2008 9:15 AM
14-02-2008 12:37 PM
14-02-2008 8:16 PM
download upload
weds 21:28 874kbps (109kbs) 342 kbps (42.8 kbs)
thurs 08:49 907kbps (113kbs) 342 kbps (42.8 kbs)
thurs 08:50 925kbps (116kbs) 341 kbps (42.6 kbs)
thurs 20:05 925kbps (116kbs) 343 kbps (42.9 kbs)
which seems pretty stable to me....
14-02-2008 8:38 PM
Quote from: jelv Check that the MTU setting on the router is the same or larger than the MTU setting on the PC. A friend of mine saw his speed nearly double when he corrected that error.
How do I do that please? I've done the DrTCP thing and changed the settings, but I can't see anything about MTU in my router settings page, is that where I should be looking?
14-02-2008 8:40 PM
Quote from: shutter hello again, for what it`s worth, as you know, I unplug my wireless router every night..... here is the last couple of speed tests I have done,
download upload
Certainly does, as I said, maybe mine was just a glitch yesterday, but I'm taking no chances, I will get a longer cable I think and move the router so I can leave it on all the time.
14-02-2008 8:54 PM
14-02-2008 9:21 PM
14-02-2008 9:41 PM
14-02-2008 10:14 PM
Quote from: notheruser The ideas about shutting down wireless, changing frequency etc. are good, but I'm guessing that flicker will hardly want to log onto the router every night before going to bed, or before using it next day.
Changing frequency isn't a task requiring she logs on to the router every night but just a one off task.
14-02-2008 11:16 PM
Of course you're right! (Note to self - think twice, write once!) Shutting down wireless though, would require login.
Quote from: geezer
17-02-2008 11:36 AM
I have put this set up in place in two houses now and it means the router stays on all the time but the wireless does not. You can have the wireless wherever you like, even in the garage.
look here..
http://www.solwise.co.uk/net-powerline-pl-85pew.htm
and here
http://www.solwise.co.uk/adsl-sar605eh.htm
- « Previous
- 1
- 2
- Next »
