Turning my router off
- Turning my router off
- « Previous
- Next »
Re: Turning my router off
23-11-2012 10:40 AM
It was my intention to fit the ADSL faceplate, but I stalled when looking at a couple of different instructions online because they all say 'remove the wires from the faceplate ... attach those wires to ... terminals ... on your new ADSL faceplate'. I stalled because there are no wires on my current faceplate and I thought to myself that surely I should not take the wires from the back of the box. When not really knowing what I'm doing, it's ok for me to follow instructions laid out, but when there is variance from those instructions, in actual, I can't rely on my own unknowing to make a decision in how to adapt those instructions. Unless in my case it really is as simple as just plugging the ADSL faceplate in, but I can't imagine that would be right.
23-11-2012 11:41 AM
The wires on the back of the "back-plate" ie the A & B terminal that you showed in the photo, you aren't allowed to touch, just anything connecting to the front plate.
Let me ask you the question about the phone another way and I can then make suggestions based on that and give you precise wiring details if you need them. Question - where would you prefer to have the phone instrument itself and is it corded or cordless?
23-11-2012 12:07 PM
Quote Let me ask you the question about the phone another way and I can then make suggestions based on that and give you precise wiring details if you need them. Question - where would you prefer to have the phone instrument itself and is it corded or cordless?
I appreciate that very much, thank you. I have a cordless and prefer my base unit where it currently is, bolted to the inside back of my desk, relatively out of sight (I don't need direct and immediate access to it for everyday use, but can do so easily when I need to plug it into my router to update its firmware - meaning it also needs to be near my router). This means I have also to have my base unit on the phone extension I'm using, which also runs to and is fixed to the back of the desk.
23-11-2012 5:13 PM
Which filtered faceplate is it you've got, is it the ADSL v1.0 ? Can we have a picture of the back of it, as there are 2 versions (at least).
23-11-2012 5:47 PM
Re: ADSL faceplate. I haven't even bought one yet. I'd checked the current faceplate & box first to make sure all was in order and looked like the instructions I've seen. If it was and I was sure I could do it, I was then going to buy one from Clarity or Adslnation and fit it (intending to simply plug my ADSL extension into it, as mentioned); but with no wiring attached to my current faceplate, that threw me. So if I get one, pre-filtered for the phone, can I simply attach it like my current faceplate and either plug my ADSL extension into it, or hardwire the ADSL extension onto the AB slots?
23-11-2012 6:02 PM
23-11-2012 6:16 PM
23-11-2012 8:42 PM
If you want a slightly neater solution and want to spend money, buy the Filtered Extension socket here (and a disposable IDC tool from the tools page) and use that instead of a Secondary socket.
Or if you want a slightly better cheap IDC tool there is this one.
23-11-2012 9:32 PM
23-11-2012 11:43 PM
There really is no point in "better" cabling for ADSL. None of the standard cables are shielded and to be quite honest in your situation I would think it a total waste. Such cables tend to be a lot bulkier and whether you could get one with a White shealth is also debatable.
Remember this is a two pair CW1308 cable and is priced per metre but is technically no better than what you've got, and you'd want the 3.5mm clips.
24-11-2012 10:21 AM
- « Previous
- Next »
