Trying to get the most speed out of my Fibre?
- Trying to get the most speed out of my Fibre?
12-08-2014 10:39 AM
I read all about the 10 days DLM and was hoping this would increase. For the first 48 hours it was. On the end of day 2 I was getting 54mb/s and 15ms ping and was quite pleased.
Now for the last 4 days it has dropped. And keeps dropping it is now 37mb/s and I am getting 30ms ping.
I am paying for the 76mb/s Fibre service so it annoys me immensely that I am getting the 38mb/s speeds and also that my ping has went to the same it was with DSL.
So I am trying to see what I can possibly do to get my DLM to increase this.
So I have bought a new cable to connect between my Openreach modem and the Face plate.
I have moved my router closer to the modem and bought a CAT6 Shielded cable. And I have shelled out £100 for a Asus AC56 router.
Are there other things I can do. I have a phone extension cable coming from the faceplate to upstairs. There is conflicting info if this will affect Fibre speeds or not.
Do I need a filter on that extension?
Would changing the extension cable from regular twisted pair phone cable to CAT5e and using this for the phone improve things?
How about changing the openreach modem - there is conflicting reports saying the Huawei HG612 when flashed with custom firmware is a better modem than the ECI modem the open reach technician gave me.
Is there anything else I am forgetting.
I want the most every last drop I can get from this fibre connection. I am not someone who cares about it will only increase your speeds by 1meg that people often say when you do things.
Re: Trying to get the most speed out of my Fibre?
12-08-2014 10:49 AM
1) Get a better modem first off, the Billion 8800NL is very very good and gives higher speeds than the Openreach modem did and gives you line stats too.
2) The engineer should have put a new filtered face plate which means the telephone and extension line is filtered from the master stocket and you do not require any microfilters. (if it has been done right - make sure it has)
3) Try use cordless phones if you can and get rid of any extension leads from the master stocket.
4) Using a very high quality RJ11 cable may help if yours isn't very good but you will find this is least of your issues, but is worth checking out.
5) Sort these things out first so you know you have a nice clean setup on your side. After all this is VDSL we are talking about and not fibre infact, VDSL is heavly effected by crosstalk.
(http://www.increasebroadbandspeed.co.uk/category/crosstalk-and-vectoring)
Give it some time to settled down and try not to unplug your modem as it could just make things worse. Sort out what you can if it makes you happier.
12-08-2014 10:52 AM
12-08-2014 10:56 AM
Quote from: swatboy79 1) Get a better modem first off, the Billion 8800NL is very very good and gives higher speeds than the Openreach modem did and gives you line stats too.
Searching for this it mentions this is a router and not a modem.
http://www.broadbandbuyer.co.uk/products/18474-billion-bipac-8800nl/
"Billion BiPAC 8800NL Dual-WAN ADSL2+/VDSL2 Fibre Wireless-N Router (300Mbps)"
Are you sure this is the replacement for the BT openreach modem and not the replacement for the Thompson pile of rubbish router that you are referring to.
If its the replacement for the router like I say I have bought an Asus AC56u router which from all websites it is regarded as the best you can get.
12-08-2014 10:56 AM
Quote from: chenks76 DECT. don't those play havoc with WIFI?
I have DECT phones in the house and WiFi works fine for me as I'm sure it does for many others.
12-08-2014 10:59 AM
Quote from: chenks76 on point 3 - use you try to use cordless phones, i assume you mean DECT. don't those play havoc with WIFI? usually the advice is to avoid DECT if at all possible?
Can someone from plusnet confirm 100% yes or no on whether extension cables from the master sockets affect fibre.
I say this as I have been recommended the same as the first replier said to do. But on google searching I have seen this only applies for DSL and not fibre connections.
I ask as I really don't want to remove my phone extension as we need the phones upstairs. But at the same time I want the most out of this fibre speeds so if it is knocking considerable speed off my line I will have to do it.
12-08-2014 11:01 AM
The world is full of devices, I have microwave and 6 Dect phones in my house all on the same specific frequency and behaves itself (you will find the microwave is the noisy one :D).
Other wifi AP's will cause WAY more interference and choosing channels wisley is key.
Dect phones (qood quality ones i am speaking for - Panasonic) will be on a specific frequncy and quite clean and controlled.
You don't need silly phone extensions mucking up your internet.
Choose your channels wisely and there will be no issues (Use andriod app wifi scanner to check where neighbours are)
12-08-2014 11:04 AM
Quote from: anthgood
It is a VDSL2 modem (thats what FTTC) is. I am using one. It is a Modem/Router.
I use the RJ11 Cable conneced to the Phone socket and then the one and only Gigabit port is connected to my houses infractructure (various switches and AP)
12-08-2014 11:07 AM
anthgood, you do release that you do not actually have Fibre it is VDSL? You have FTTC which means the last bit of copper which you always have is doing the job of your internet, just like your ADSL2+ did before that and so on.
As long as you have copper entering the house, you will have the same rules as you always did..
12-08-2014 11:47 AM
Quote from: swatboy79 My wifi runs like a champ (2.4 and 5GHz) always has. I really don't get the beef with dect phones.
indeed, but DECT uses 2.4GHz doesn't it? which is what WIFI uses as well (unless you're one of the few using 5GHz).
in an already congested spectrum, why purposely add another device in your home that could potentially cause problems.
12-08-2014 11:57 AM
http://www.ofcom.org.uk/static/archive/ra/publication/ra_info/ra193.htm
http://www.radio-electronics.com/info/wireless/wi-fi/80211-channels-number-frequencies-bandwidth.php
12-08-2014 12:04 PM
Trust me, your neighbours wifi AP channel selection will have far more impact. I can't say anymore.
12-08-2014 12:22 PM
all i'm saying is why potentially add a problem thru choice.
i quickly looked at various DECT phones on argos (including Panasonic) and they all stated 2.4GHz.
12-08-2014 12:35 PM
However for Panasonic http://eng.faq.panasonic.com/app/answers/detail/a_id/11025/~/dect-phone-frequency-information.
Quote DECT phone frequency Information.
UK DECT works on frequencies 1.88 - 1.9 Ghz.
Wireless networks are on 2.4 Ghz so the UK DECT phones do not interfere with wireless networks.
There can be problems in the USA (USA Models) where the cordless phones can use the same frequencies as the wireless networks (2.4GHz).
12-08-2014 12:39 PM
Q&A section asking about 2.4Ghz
